TC-P50G20 SC and SS board replaced and blow again ?
  • autoperformance
    • Jul 2019
    • 35
    You can go here to see all the step I do. But I didn't received lot of help.
    https://www.badcaps.net/forum/showth...065#post915065
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • ermals
    Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
    by ermals
    Hi all!
    I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
    1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
    2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
    3. I've checked voltages...
    08-01-2022, 10:35 AM
  • jb_Bak
    by jb_Bak
    CN6401
    Pin 01 NC
    Pin 02 NC
    Pin 03 "BL_ON": 0V
    Pin 04 "N/C"
    Pin 05 "STBY 3.3V": 3.5V
    Pin 06 "GND": N/C
    Pin 07 "AC_OFF"...
    09-27-2021, 04:52 PM
    After all of...
    07-13-2024, 08:14 PM
