LG 50PZ550T-ZA Problem
  • StephenU
    • Dec 2013
    • 230
    • United Kingdom
    Hi Everyone looking for some advice on the repair of this TV (If it's not the panel that has gone bad.!)
    Said to a friend I would try and help repair his TV.
    TV is an LG 50PZ550T Plasma, the TV powers on and starts up without any problems, fault is the screen seems to have a 'Washed out' look (Unsure what this is called...See picture attached. ) Colours seem to be all over the place. After a short time the screen seems to go normal and works fine, but when cool and first starting the set up it comes on with the fault mentioned. If anyone could point me in the right direction It would be very much appreciated. I haven't had the chance to open the tv as yet, thought I would post a couple of pics on here to see if it would be worth investigating further.
    Many Thanks,
    S.
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: LG 50PZ550T-ZA Problem
    I think it looks like a Zsus problem. Have you checked the voltages are as given on the back of the plasma panel. ie Ve, Vsus etc. Perhaps a bad (dry) solder joint on the Zsus board
    • StephenU
      • Dec 2013
      • 230
      • United Kingdom
      Hi dick, I haven't managed to get the set open yet but I'll get round to it within the next couple of days, I was just wondering if this one would have been worth investing the time in, thanks for the reply I shall get it open and get a good visual on all boards along with measuring all voltages mentioned.
      Kinds Rgds,
      S.
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        Perhaps someone else could offer some insight into the problem. I see it's a full HD, 3D tv so would be worth trying. Search the forum using the search box above for Zsus problems.
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          yes
          • StephenU
            • Dec 2013
            • 230
            • United Kingdom
            Hi everyone, just closing out this thread sorry its took so long, but I finally got the time to resolve the problem on this one. Ordered a new Zsus board like for like and it has cured the problem. All voltages on the PSU were fine and didn't see any visually dodgy looking components on PSU or old Zsus so fingers crossed he can get another couple of years out it now.
            Thanks for help @dick_barton
            • Unspun01
              • Jun 2011
              • 343
              Yes, this definitely appears like a ZSUS problem. Good that you ordered a replacement ZSUS and the TV is now working.
              If you have the old board out, can you please check the condition of the solder joints on the underside of the board for the two large copper coils between the heat sinks?
              If the solder for these coils looks cracked, or otherwise burned, you may be able to re-solder them and see if the board works.
              Let us know.
              • theone111
                by theone111
                3. Problem: TV shuts down
                07-22-2024, 10:36 AM
              • Krisby
                Protek 506 DMM Problem/Fault
                by Krisby
                Hello badcaps.net Forum People,
                I have a Protek 506 DMM which has a problem with the Diode Test Function and with the 4V range of the Voltage Measuring Function. I have posted this on three other forums, but have not been able to find out the source of the problem.
                It seems that the Diode Test problem is linked with the 4V range Voltage Measuring problem, so I shall just focus on the 4VDC range to simplify things.
                When I select the DC voltage function on the rotary switch of this DMM, the display alternates between showing 3.999V and 0V. If I test a...
                10-14-2020, 06:26 PM
              • Zeonalbasta
                Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                by Zeonalbasta
                i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                09-13-2024, 01:17 PM
              • Gibon378
                Problem with stopping audio and video for no reason
                by Gibon378
                PC Specs:
                • CPU: Ryzen 5 1600
                • GPU: GTX 1080 Palit JetStream
                • MOBO: ASRock ab350 PRO4
                • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                • PSU: XFX 650W (don't remember what model)
                • OS SSD: ADATA SP920
                • OS: Windows 10 21H2
                Problem description:
                Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                11-19-2022, 09:41 AM
              • perzyk23
                Lenovo T580 - LCD Panel problem - error 0288
                by perzyk23
                Good morning,
                I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                10-25-2024, 12:42 AM
