LG OLED Screen protection remover
  • freeman3020
    • Jun 2019
    • 30
    • Palmo
    Hi all
    I have 2 LG b8 OLED TV with problem of protection mode as i think , i realized that if i disconnect any cable from 4 ribbon cable of Panel , T-con will be in protection mode , so the the TV will not power on , i connected all panel cables and disconnect the bottom cable from main board to T-CON the TV power on with sound without any picture , but its mean main board is good, when connect all cables screen flicker white then off, relay on power supply click ,then off , its mean there is order to protect boards , how to remove this protection ,and let TV to work not perfect but 50%
    Thank You
  • petehall347
    • Jan 2015
    • 4437
    Re: LG OLED Screen protection remover
    might be back-lights fault
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      LG OLED TVs do not have Backlights like Samsung QLED TVs.
      • petehall347
        • Jan 2015
        • 4437
        wont be back lights then
        • petehall347
          • Jan 2015
          • 4437
          Tcon ?
          • freeman3020
            • Jun 2019
            • 30
            • Palmo
            Tcon ?
            I replaced T-Con from working screen, same problem
            • budwich
              • Jul 2015
              • 3097
              there are posts in the forum for using a service remote OR using a computer wave file to generate the IR signal from a phone output jack to an IR sender. this is used to reset the protection is the service menu BUT if the issue is the panel, it will come back on after a number of attempts / turn on cycles.
              • Amedtronic
                • Oct 2019
                • Nederland
                please in details how to do that
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  QFT, OLED is not LCD!
                  And to the TV noobs, "LED" doesn't automatically mean LCD with LED backlights, FFS!
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                  • Kalman27
                    Lenovo IdeaPad Slim 5 14IAH8 - Type 83BF OLED Blank screen
                    by Kalman27
                    We have a Lenovo IdeaPad Slim 5 14IAH8 - Type 83BF for repair. The original issue the OLED screen is blank.
                    We have replaced the OLED screen with the exact model, also we replaced the LCD cable, but no luck.
                    I think there is something with the motherboard. I don't really have experience with OLED screens so far, so not sure how it should work. I have seen some laptop comes with a separate controller board, but this model does not.
                    Also, there is an error in Windows device manager - This device cannot start (Code 10) - Intel(R) Serial IO I2C Host Controller...
                    06-17-2025, 05:52 AM
                  • Diah
                    Guide : Philips OLED TVs how to remove the protection mode NVM.EED
                    by Diah
                    OLED Cells over all OLED brands are easily its drooping more currents will be increase which it trick the SOS signal which T-CON driver boards will send to the Mainboards... the NVM software on the Mainboards will shutdown the PSU..
                    not all fault at OLED are bad-- some issue can remain working with minimal issue at displaying generate
                    Philips OLED TVs. we can switch the protection code to off via binary.
                    - ropy it on empty usb stick and insert it while the tv off at USB 1
                    -turn on the Tv it will restart 2 or 3 time then plug out the stick and turn on the...
                    04-21-2024, 03:21 PM
                  • reformatt
                    by reformatt
                    07-31-2025, 08:37 PM
                  • smic717394
                    by smic717394
                    07-25-2024, 10:16 AM
                    ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                    This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                    09-07-2024, 04:30 AM
