Vizio m422i-b1 no channels
+ More Options
Posts
  • Malachi
    • Dec 2015
    • 1077
    • Usa
    Just picked this tv up for free. All hdmi inputs work but the tv does not find any channels when scanning with cable. I haven't tried with an arial antenna.
    Is this a main board issue? EEPROM?
    I searched on here but didn't find anything.
  • SLK001
    • May 2014
    • 264
    Re: Vizio m422i-b1 no channels
    Plug a 36" length of 18-20 ga wire in the antenna jack and scan for local channels and bend it vertically. You have to select antenna in the setup (somewhere). If it doesn't find any, I would suspect the tuner itself.
    • Malachi
      • Dec 2015
      • 1077
      • Usa
      I have antenna I can try. Just have to dig it out.
      • Malachi
        • Dec 2015
        • 1077
        • Usa
        Just tried the antenna. It picks up local channels. This is strange.
        Decided to try to scan for cable channels for the third time and it tuned them in.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • SS454
          vizio e650i-a2 backlight flashes then turns off
          by SS454
          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
          panel: au optronics T650HVN05.4
          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
          https://www.shopjimmy.com/vizio-56-0...-power-supply/
          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
          08-20-2020, 03:57 PM
        • howardc64
          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
          by howardc64
          Failure Symptom
          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
          Where is the short?
          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
          05-27-2025, 02:56 PM
        • howardc64
          Vizio SmartCast TV software bug that looks like hardware
          by howardc64
          Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
          It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
          11-16-2024, 05:17 PM
        • r2digital
          Harmon Kardon AVR340 no sound on 4 channels
          by r2digital
          Hello, i had this amp sitting in the closet knowing that none of the channels were working. After taking it all apart i found 4 bulging main filter caps so i went ahead and replaced those with low ESR kmet caps. However after doing this it only restored sound to Surround L, Surround R, and Center channel. The main speaker fuse on the transformer F905/F906 keeps blowing so i decided to remove all of the transistor's on those 4 channels and measure them. All transistors appear to be in good working order(turned receiver on with none of them installed and fuse still blows). Checked dual emitter resistors...
          03-09-2024, 01:33 PM
