Sony KDL-46VL130 curbside rescue has vertical bars and lines
  • Euthymia
    • Dec 2015
    • 4
    A week ago I spotted a large LCD TV that someone had set out at the curb, and having revived more than one "dead" LCD display by replacing the caps in the switching power supply, I checked it out, saw that the screen looked intact, although it looked as if it had been sitting outside for a few years. There was dirt and cobwebs in the ventilation slots and the RCA connectors were actually rusted, but it had the magic date of 2007 on it, which is right in the cap cootie years so I figured I would take it home and see what happened if I plugged it in.
    It had no problem powering up, showed a mostly red-tinged screen, then I tapped it on the top and the picture flickered to life showing a mostly clear image with some red tinting on the right hand side.
    Encouraged, I watched some Amazon Prime for a while to see how it would hold up to heat stress, and it did okay. Let it sit overnight unplugged, came back to it with some DeOxit for all the video connectors and the control panel on the top. Went into the picture menu with the remote and did a reset and poof! suddenly it went postcard-perfect, yay, I got a free upgrade to a 46" TV from my current Samsung 40" (a $40 cap replacement rescue). Watched several hours of streaming HD on my "new" TV, marveling at the size and quality, wondering if it would hold out.
    Nope, as it turned out, next day it had a red vertical bar down the right side, with "slow" pixels leaving trails. Took the back off, blew the cobwebs and dirt out, sprayed DeOxit Gold on every visible connector, removed the T-Con board, put heatsink compound on the chips, cleaned the ground pads, reinstalled it, and now had a white vertical bar down the right side.
    Poking around with a non-conductive probe (chopstick) revealed pixel flashes when I would touch it to the LVDS cable going into the T-Con module from the main board, no problem anywhere else.
    Since Internet wisdom says that the T-Con board is indicated in most cases of vertical bars, I ordered a $10 eBay replacement, figuring I had a 50-50 chance of getting another bad T-Con board, but at least it might be messed up in a different way and I would know that it was the problem.
    T-Con board arrived today, so before doing anything I powered up the set, and whoa, now I have vertical lines all across the set. Swapped the boards and no change in that status. So I guess the problem is not a bad T-Con module and now I have a spare one in case the one in the set ever fritzes. Strange, because I have read the Sony T-Con Troubleshooting Manual, and it points to the T-Con board rather than source or gate drivers on the panels. Might be wishful thinking on my part.
    I found this thread about panel bonding shims. Given that it seems to have sat outside for a few years, those bonds might have become compromised, if they were not already due to Windex abuse. Something must have caused the TV to be retired in the first place.
    Since this is what I consider to be major surgery (although I do have the back off already, getting that bezel off seems like no fun), is there anything else I should check before ordering the silicone pads from Amazon and giving it a try? Do you think the shimming will help?
    Behold the current state of my picture, and thank you in advance:
    • 12181
    • U.S.
    Re: Sony KDL-46VL130 curbside rescue has vertical bars and lines
    Test there: https://www.youtube.com/watch?v=vCExlSnG4yY
      • 12181
      • U.S.
      https://www.youtube.com/watch?v=xHst6pKLtTE
        • 12181
        • U.S.
          • 12181
          • U.S.
          If you haven't already try cleaning the tcon ribbons contacts where they plug into the tcon with ISA alcohol or a pencil eraser carefully, they can be delicate and make sure you have a good clean contact where lvds cable plugs into tcon.
          • Euthymia
            • Dec 2015
            • 4
            Thank you! Yes, I have cleaned all the contacts, with DeOxit Gold. So from the symptoms it's looking like the panel bonds are compromised, and I'll get with some pads and see if shimming them cures the problem.
            Given the failure rate on these connections, I wonder what the process is on these. Is it an actual solder bond that goes bad over heating/cooling cycles, or is it merely held in place by an adhesive or what?
              • 12181
              • U.S.
              In most of those examples I believe it's worn out adhesive, lots of videos on youtube, most use very expensive bonding machines to fix these issues, there's also some diy videos where they fix them without these machines. Can be risky tho if the diy fix fails, big problem, myself I'd rather shim them if possible.
                • 12181
                • U.S.
                Still using a tv I shimmed 5 years ago as this pc monitor, it gets quite a workout every day.
                • x_orange90_x
                  Samsung UN46C8000XFXZA vertical bars/horizontal lines
                  by x_orange90_x
                  I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                  The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                  09-04-2023, 12:09 PM
                • ninja_zx11
                  Sharp LC-70LE650U vertical black and red bars
                  by ninja_zx11
                  70" LED TV is Sharp LC-70LE650U.
                  Initial problem was horizontal lines and slow motion lurrs on the bottom left of the screen. So I removed both the left and right ribbon cables from the T-con board and tried to clean it with alcohol and when I put it back, this issue appeared. I tried carefully reinserting the ribbon bon cables but same thing. I checked the traces of the ribbon cables with magnifying glass and everything looks good. I cleaned the small jumper ribbon cable on the left side of the screen which cured the horizontal line and slow motion blurs...
                  07-07-2023, 11:27 PM
                • Daren87
                  Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                  by Daren87
                  I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                  08-13-2023, 03:25 PM
                • JesusJones
                  Samsung Plasma Intermittent Vertical Bars (repeatable) PN50B430
                  by JesusJones
                  Trash picked this plasma for parts and found it had some bad solder joints. It powered on after reworking most of the boards and seems like it may even work.
                  The symptoms is, when showing a picture of bright (mostly white) intensity (within the affected area only) a vertical strip 2 3/4" wide will begin to fuzz out (just to the right of samsung logo, 16 3/8" from screen edge), and soon turns black (from top to bottom). Changing to a darker scene immediatley ater will cause the black stripe to fade back in (it fuzzes and clears up again) and it starts working just fine....
                  04-13-2021, 01:45 PM
                • mopenstein
                  Looking for Vertical IC for RCA Chassis CTC159L CRT
                  by mopenstein
                  I'm working on my 27" RCA console TV built in 1990. It had some vertical rollover for a few months that went away after being powered on for a few minutes. I had been meaning to open it up and check it out but it had total vertical collapse before I could get to it.
                  Now that I have the time I opened it up and found a couple leaky capacitors around the vertical ic. So I figured the caps went bad and cooked the vertical IC.
                  I got the caps out and replacements on order. But when I took out the Vertical IC I saw that the chip numbers have been almost completely wiped...
                  09-24-2023, 10:41 AM
