Toshiba DVD player disc stops spinning
  • Fast Alpha
    • Feb 2013
    • 245
    • United Kingdom
    I have a Toshiba dvd player SD3005KB-2 it sometimes states bad disc, freezes while playing and stops automatically. Any advice please?
    http://www.hse.gov.uk/pubns/indg305.pdf
  • Fast Alpha
    • Feb 2013
    • 245
    • United Kingdom
    Re: Toshiba DVD player disc stops spinning
    Here are pictures.
      • 22151
      Have you tried cleaning the laser lens cover
      • R_J
        • 9624
        You could also check if the spindle motor spins freely, if the motor does'nt spin properly it can show this type of problem, especially when the motor needs to run at a slower speed.
        • Fast Alpha
          • Feb 2013
          • 245
          • United Kingdom
          What lubrication can I use on the rails by the lens. Makes a sticking sound.
          WD-40® Specialist® Water Resistant Silicone Lubricant
          https://cdn.badcaps-static.com/pdfs/...a2cab76f5c.pdf
          • Fast Alpha
            • Feb 2013
            • 245
            • United Kingdom
            More pictures of inside the DVD player.
            I found out with my Toshiba DVD video player Model no. SD3005KB-2 works properly, when I take the lid off, the top lid, when I put it back on it states bad disc, it spins with the round thing making red lights and clicking noises.
            More information here found out the caps are ZHN and KSD!
            • petehall347
              • Jan 2015
              • 4450
              • United Kingdom
              lid on with or without screws ?
              • Fast Alpha
                • Feb 2013
                • 245
                • United Kingdom
                If I clean the disc with isopropyl alcohol then it plays, I left all the cables unplugged overnight then it works a bit better. I put sewing machine oil on the pulley part of metal.
                • Fast Alpha
                  • Feb 2013
                  • 245
                  • United Kingdom
                  I think this ribbon cable need s to be replaced where do I find replacement from?
                  180mm/18cm length
                  12mm/7cm width
                  Same side contacts.
                  Here's pictures.
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    Is the other end damaged ?
                    The length is required, the pitch and number of contacts and also if they are on the same side or opposite (forward/reverse).
                    You could always trim off the damaged part and sand back the insulation if there is enough slack in the cable.
                    • R_J
                      • 9624
                      That cable looks perfectly fine, if the cable was bad the dvd would not work at all. The only way that cable would go bad is if you damaged it in some way.
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        The left edge in the first photo looks iffy although it could be the blurry photo/lighting.
                        • petehall347
                          • Jan 2015
                          • 4450
                          • United Kingdom
                          you never answered about the cover . if it works with it off i suspect screw length or something
                          • Fast Alpha
                            • Feb 2013
                            • 245
                            • United Kingdom
                            Without screws it still states bad disc.
                            How do you sand back the insulation to the metal pins ?
                            • diif
                              • Feb 2014
                              • 6978
                              • England
                              Slightly longer at 20cm but it should be ok. https://www.aliexpress.com/item/1836291997.html
                              Just trim the bad piece off, I use a scalpel or safety razor blade, then carefully scrape or use fine sand paper to sand away the plastic coating.
                              • Fast Alpha
                                • Feb 2013
                                • 245
                                • United Kingdom
                                I just cleaned the optical lens must of touched it. Spins like crazy. Remember to clean the lens with isopropyl alcohol to get it to spin to win.
                                Can you please give me a link to Farnell, they sell it there I got to buy some items there too.
                                • petehall347
                                  • Jan 2015
                                  • 4450
                                  • United Kingdom
                                  check out your local motor factors for electrical cleaner spray . then check whats in it . stuff i get is 97 percent isopropyl .and its cheap to buy . yellow can
                                  • petehall347
                                    • Jan 2015
                                    • 4450
                                    • United Kingdom
                                    so it works with lid off still ?
                                    • diif
                                      • Feb 2014
                                      • 6978
                                      • England
                                      The link is rather long, just do a search for this part number. 687624200002
                                      • Fast Alpha
                                        • Feb 2013
                                        • 245
                                        • United Kingdom
                                        https://www.halfords.com/motoring/en...-cleaner-250ml
                                        No states bad disc, but it spins the disc.
                                        Thank you.
                                          09-06-2024, 05:33 AM
                                          Toshiba Tecra C50-EC Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Tecra C50-EC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C50-EC boardview and C50-EC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Tecra...
                                          09-06-2024, 09:01 AM
                                          Toshiba Portege X30T Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the Toshiba Portege X30T Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X30T boardview and X30T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          09-06-2024, 07:33 AM
