Panasonic P60ST60 7 lights, then 8 lights, then 10
  • perardua
    • Aug 2019
    • 5
    • US
    I am so thankful to have found this community. Don't think I'd have a chance in hell at fixing my current situation if not!
    Recently I went to turn on my Panasonic ST60 and was greeted with a lovely light show of 7 red blinks. I fell asleep watching the TV so I don't know if there were any pops or noises when it shut off last.
    Apparently 7 blinks indicates SD/SU/SC so I took the back panel off and troubleshooted as follows.
    Unplugged SD board, 7 lights still
    Unplugged SU board, 7 lights still
    Unplugged SC board, now 8 lights
    Replugged SC Board with SD/SU unplugged, ground screws removed, and jumper at SC50. 7 lights
    At this point I am hoping this confirms simple SC Board fault and I can order the part and be on my way.
    Disconnect SC2, SS11, P35, 3 white ribbons at the A-board to hopefully get a solid light and isolate issue to SC Board. Nope. Now 10 blinks
    Where does this leave me? Attached are pictures of my panel and boards. I don't see any visible shorting.
    Could SC and A board failed at the same time or am I not understanding the results of my testing?
  • perardua
    • Aug 2019
    • 5
    • US
    Re: Panasonic P60ST60 7 lights, then 8 lights, then 10
    https://my-secure.justanswer.com/que...b2d1d3eb847c8e
    This 10 blink diagnosis sounds very similar to my issue, and P60ST60 troubleshooting tech guide states 8 blinks is normal to indicate SC board. Maybe I should just get a SC board and see what happens given how cheap they are these days. Any thoughts?
    And did I ruin my set because I might have plugged P35 back in while the set was ON? I don't know which were plugged in exactly, but I plugged a few back in before I realized it was still plugged in. Ugh. No sparks or anything crazy, and it all cycles through all the same light sequences as before.....
    Edit: Actually is the panel even powered in the flashing state? I think it turns off when the error codes trips and goes into SOS mode flashing lights, right? If so, it was sitting plugged in SOS mode for about 5 minutes before I started plugging the cables back in.
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      I think the new SC Bd will fix your problem.
        by sam_sam_sam
        After all of...
        07-13-2024, 08:14 PM
      • canadaboy25
        Panasonic TC-P54VT25 No image. A or D board?
        by canadaboy25
        I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
        The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
        I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
        01-17-2021, 01:06 AM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • dajoker
        Panasonic th-p50s10d - blinky red, SC board go boom
        by dajoker
        My old plasma died when one night recently. When I got to it it was giving a 3.3v sos (3 blinks).
        I chased my way through the PSU, and a board, with no results.
        Replacing a few bulged caps in the PSU, I eventually got to the SC board that had piles of shorts, a quick cheap replacement from china and the tv powers up again, except
        I only have the right half of the picture.
        Left half is completely blank.
        now the c3 board running this side of the screen has its 3.3 and 5v onto the buffer ic and its got the 60v, so that all seems good.
        all the other voltage rails...
        09-24-2024, 04:39 AM
