Panasonic TC-P65S2 no good HDMIs left - Suggestions?
  • WannaTheater
    • Jun 2017
    • 18
    Several years ago during a heavy storm, I got a surge on my cable line which took out the cable box, the A/V receiver HDMI connected to it, and the HDMI input on the back of the Panasonic TC-P65S2. (It actually took out BOTH HDMI inputs to the TV). But HDMI3 still worked (on the side of the TV). SO for years I just used the side HDMI input-
    Two weeks ago the same thing happened - Cable box, A/V receiver HDMI, and the last of the Panasonic HDMI inputs. I've already replaced this TV, and I am at a point where I need to determine what to to with this broken beast. It is still in "like-new" condition (with the exception of it not working...)
    Options:
    1) Take it to the dump
    2) Try to find a replacement board (TNPH0831AF) and cross my fingers that it will bring this back to life, then perhaps sell it for a couple hundred dollars?
    3) Strip for parts? (Is there a market for these parts?)
    Being surface mount, trying to replace individual components seems like it would be VERY difficult... especially since I only have tools for repairing through-hole-type boards.
    Any suggestions?
  • CapLeaker
    Leaking Member
    • 8206
    Re: Panasonic TC-P65S2 no good HDMIs left - Suggestions?
    you've got 2 choices. replace the main IC on the main board, or replace the main board. That's about it. There is no HDMI switching IC, as the HDMI goes straight into the main IC.
    • WannaTheater
      • Jun 2017
      • 18
      Donated to a friend of mine-
      • armoured_smiler
        Panasonic Tx-40cx400b top left half screen not displaying correct
        by armoured_smiler
        Trying to work out if this is TFT problem or TCon issue.
        The TV powers up but the top half of the screen, from the right it is OK, but as you look across to the left halfway across it starts get duller and duller until it is very dark on the lefthand side, currently I trying to clean the remote as it seems to have something film wise on the pads stopping it from registering buttons pressed.
        Also when changing the screen size of Windows PC display to say to a smaller pixel sizewindow, the original window displayin the top left stays/takes a few seconds to disappear?...
        04-08-2024, 03:40 PM
      • Zelek11
        Panasonic Plasma screen interference on left half of screen
        by Zelek11
        My Panasonic Plasma model P55VT50 has started displaying "interference" on just the left half of the screen only (left when facing the screen). Sometimes it's concentrated in about the first 30 seconds after startup, then disappears. Other times it's fine at startup and then randomly does it later on. When it flashes the interference it's very quick and doesn't stay on the screen unless it flashes repeatedly in a row.
        This image is a screen shot from a video I took. This is an example of the interference at its worst. Often the interference is much smaller...
        10-14-2022, 04:54 PM
      • Andre Gilbert
        by Andre Gilbert
        Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
        Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
        11-20-2024, 08:52 PM
      • howardc64
        TCL 49S405 double image
        by howardc64
        LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
        This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
        06-23-2025, 03:20 PM
      • karatzdi
        Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
        by karatzdi
        I know some might say... just buy another one. Sell it as parts..!
        So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
        Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
        Spent some time downloading the Service...
        06-11-2024, 08:38 AM
