Benq W1070 projector power supply short
  • tibimakai
    • Jan 2012
    • 3680
    I have picked up this pj, that was dead, no sign of light.
    It was fully packed with dust and it cooked itself.
    Safety switch wires were backed, that the insulation it was mostly gone and hardened.
    After cleaning and replacing those wires, I have started measuring and I have found an open T6.3A/250V F601 fuse.
    Also I have found Q601 mosfet completely shorted.
    SM is available, at elektrotanya. Power supply is on page #18.
    My question is, if this FET has shorted, what else could be damaged? IC601 may be damaged as well? Rectifier is OK.
    Any help would be appreciated.
    Re: Benq W1070 projector power supply short
    The IC that drives the MOSFET's Gate and the components connected to the Gate may be damaged also, plus if there is Source resistor, it can be blown too.
    • tibimakai
      • Jan 2012
      • 3680
      Thanks Bud for your help.
      Pins #10 and #8 are not shorted to ground.
      I have measured the components around the transistor, and nothing seems damaged.
      • yokoono
        • Apr 2010
        • 515
        When the mosfet is short, the 310v voltage reaches the integrated controller. That destroys it irremediably. Replace the integrated controller, mosfet, resistors, diodes between the integrated output and the mosfet gate. Check the rectifier bridge.
        • tibimakai
          • Jan 2012
          • 3680
          I tried replacing only the Mosfet, (to me it seemed like nothing else was bad) the IC was three weeks away anyway.
          It worked. Now I need to clean it, it is worse than a neglected desktop pc.
          Thanks guys, for helping.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
            03-31-2024, 02:12 PM
          • Babbar
            by Babbar
            04-12-2024, 01:12 AM
          • playit
            450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
            by playit
            hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
            09-02-2023, 02:43 AM
          • M1NEBLANK SHOW
            MSI B250 Gaming M3 Short circuit in CPU power supply circuit
            by M1NEBLANK SHOW
            Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
            (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
            Schematic and Boardview here
            04-04-2025, 03:57 PM
