N8-42P650A11 plasma power returns to normal if i remove ribbon on middle board
  • Packard93
    • Jul 2016
    • 81
    Power returns to normal when I remove the that middle board disconnected my voltages go to normal .The one in middle that describe looks like a tcon board . I get multiple clicks with all boards connected . But when I disconnected that little rectangle one which looks like t-con board my voltages come back but when I connected them back I can see the voltages cycle up and then down to 0 . The middle board disconnected seems to be my issue I guess . When i disconect the ribbon cable test the 5.3 volts I get them . After connecting the board back I get a series of relay clicks of 5 and the red light blinking with every click then the 5 volts does not remain after the clicking stops and blinks stop . The solid red light remains in front of tv power panel. So do i replace the board .
    Do i don the test this way for the other boards in this tv the same way by disconneting them. It looks like y and x supplied power to x board .
  • Packard93
    • Jul 2016
    • 81
    Re: N8-42P650A11 plasma power returns to normal if i remove ribbon on middle board
    VA VOLTS = VOLTS NONE WITH METER CONNECTED VA POINT i HAVE NO VOLTS HERE ON POWER SUPPLY BOARD ?
    VS VOLSTS = 4.5 STICKERS SAYS 54 RATED?
    • Packard93
      • Jul 2016
      • 81
      I have standby light on front of tv . I get a series of 5 clicks when I first plug it in then I get a solid red standby. .Did a board by board connect x / y individual. main and logic. Should I replace logic?
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • oldham50
        tcl t-con board 30840-000035 looking for datasheet or ribbon pinout
        by oldham50
        I have a TCL Roku 43" tv that has no picture or sound with vertical lines. I have replaced the main board which solved the no standby voltage problem. I have checked all the voltages on the T-Con board and they are ok. I suspect the VGH voltage is not present on the 2 panel boards but i can not find any marking where this voltage is identified. I am attempting to trace the VGH voltage thru the ribbon cables but need the pinout.
        05-06-2025, 01:40 PM
      • canadaboy25
        Panasonic TC-P54VT25 No image. A or D board?
        by canadaboy25
        I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
        I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
        01-17-2021, 01:06 AM
