mounts electronic vestel, 17IPS72, I checked, there are 300v, but not 5v stb, is the power supply diagram?
Hitachi 43HK15W64I led tv does not light up
Re: Hitachi 43HK15W64I led tv does not light up
these are the voltages on U2:
pin 1 = 150v
pin 2 = 0.6v
pin 3 = 0.4v
pin 4 = 0v
pin 5 = 0v
pin 6 = 0v
pin 7 = 0.9v
pin 8 = 0.4v
pin 10 = 11v
pin 11 = 0v
pin 12 = 0v
pin 13 = 0.5v
pin 14 = 8.6v
pin 15 = 8.6v
pin 16 = 11v
the voltages measured are not stable but fluctuate by a few volts more and lessComment
The voltages will fluctuate, the ic is trying to start and can not. It could be may reasons, Check all the diodes inthe secondary to make sure none are shorted, check that Q2 & Q3 are not shorted,
VCC (pin10) is too low indicating the circuit is not working correctly, the 11v is from the internal startup cell, the ic needs around 19v to operate, this voltage comes via D38 from pin 7 of the transformer. (when the circuit is working)Comment
there is one thing that I don't understand, how can there be vcc_main if Q2 and Q3 are not piloted, I would like to know in the initial instant just connected ac 220v what must be activated beyond + 400v?Comment
I explaind it in post #5 (download the datasheet) B+ Voltage (150v) is supplied to pin1 of the ic, Inside the ic is a start-up cell and in this case a start-up Management (voltage regulator) that supplies 11.5 volts for the internal 5v and 3.3v circuits. This is used only to start the ic, after a couple pulses, C109 would be charged to about 20~25v. This voltage keeps the ic running.
In standby mode, the pfc circuit will not be active so the voltage supplied to Q2 will only be the regular B+ (325v). That is enough to supply the low current demand standby circuit.
I suspect that the voltage on pin3 is too low, (you have 0.4) I believe it should be a lot higher, so check each of the resistors, R29, R30, R31, R32. one of them might be open or high in value. They may be hard to check in circuit due to there high value (619kΩ)
You could also check the voltage on each resistor, it should start at 300v on R32 and decrease after each resistor going to the ic.Attached Filesif you find these attachements useful please consider making a small donation to the site
That is possible, these schematics are for many different models. If there are no components on pin3 I think the open circuit voltage should be around 4.4v (I could be wrong)
I see pin 11 is 0 volts, check the resistance to ground, IF D30 is installed it could be shorted.
Another thing to check is C172, If you have a capacitor checkor, check its value, if not, inspect it closely, if it is a square type capacitor and the sides seem to be bulged it is likley bad.
It provides a return to ground for the primary of the transformer, if it goes open you would have this resultLast edited by R_J; 07-23-2019, 11:44 AM.Comment
I believe that is how it should operate, check the other components I suggested. Also check the resistance of the (N2) winding of the transformer and also D3,R70 and any other parts on that line between the transformer and the vcc pin of the ic. If they are all ok, it could be a bad ic.
This circuit must work before any other parts of the power supply will turn on.Last edited by R_J; 07-23-2019, 11:55 AM.Comment
I checked the resistance of N2 about 1 / 1,5ohm C172 is good both in capacity and Q (over 700), at this suspicious point of U2 I tried to look for it but I can not find it online, maybe looking for the card I will be more luckyComment
I don't understand your question. Do you mean if you disconnect the MAIN BOARD from the POWER SUPPLY? Yes the power supply will produce the standby voltage.Comment
by sam_sam_samI have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
I also have back when Light of America had these light bulbs available for yard lights
The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
While the Lithonia lighting fixture has all most certain bulb failure
So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
I have only had this light fixture for not more than a year if it... -
This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 03:40 AM
This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 09:10 PM
This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 08:40 PM
Hello Everyone!
I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died....06-28-2025, 02:57 PM - Loading...
