Hitachi 43HK15W64I led tv does not light up
  • poweron
    • May 2019
    • 371
    • italy
    mounts electronic vestel, 17IPS72, I checked, there are 300v, but not 5v stb, is the power supply diagram?
  • poweron
    • May 2019
    • 371
    • italy
    Re: Hitachi 43HK15W64I led tv does not light up
    • R_J
      • Jun 2012
      • 9623
      This might be close
      • poweron
        • May 2019
        • 371
        • italy
        these are the voltages on U2:
        pin 1 = 150v
        pin 2 = 0.6v
        pin 3 = 0.4v
        pin 4 = 0v
        pin 5 = 0v
        pin 6 = 0v
        pin 7 = 0.9v
        pin 8 = 0.4v
        pin 10 = 11v
        pin 11 = 0v
        pin 12 = 0v
        pin 13 = 0.5v
        pin 14 = 8.6v
        pin 15 = 8.6v
        pin 16 = 11v
        the voltages measured are not stable but fluctuate by a few volts more and less
        • R_J
          • Jun 2012
          • 9623
          The voltages will fluctuate, the ic is trying to start and can not. It could be may reasons, Check all the diodes inthe secondary to make sure none are shorted, check that Q2 & Q3 are not shorted,
          VCC (pin10) is too low indicating the circuit is not working correctly, the 11v is from the internal startup cell, the ic needs around 19v to operate, this voltage comes via D38 from pin 7 of the transformer. (when the circuit is working)
          • poweron
            • May 2019
            • 371
            • italy
            I checked all the diodes of the secondary and are good, even Q2 and Q3 are not shorted
            • yokoono
              • Apr 2010
              • 513
              Replace C109 (47u / 100v) with a new one. Measure the tension you have on it.
              • poweron
                • May 2019
                • 371
                • italy
                on my C109 card is 100 / 35v, I measure on him 11v, I replaced it but nothing changed
                • poweron
                  • May 2019
                  • 371
                  • italy
                  there is one thing that I don't understand, how can there be vcc_main if Q2 and Q3 are not piloted, I would like to know in the initial instant just connected ac 220v what must be activated beyond + 400v?
                  • R_J
                    • Jun 2012
                    • 9623
                    I explaind it in post #5 (download the datasheet) B+ Voltage (150v) is supplied to pin1 of the ic, Inside the ic is a start-up cell and in this case a start-up Management (voltage regulator) that supplies 11.5 volts for the internal 5v and 3.3v circuits. This is used only to start the ic, after a couple pulses, C109 would be charged to about 20~25v. This voltage keeps the ic running.
                    In standby mode, the pfc circuit will not be active so the voltage supplied to Q2 will only be the regular B+ (325v). That is enough to supply the low current demand standby circuit.
                    I suspect that the voltage on pin3 is too low, (you have 0.4) I believe it should be a lot higher, so check each of the resistors, R29, R30, R31, R32. one of them might be open or high in value. They may be hard to check in circuit due to there high value (619kΩ)
                    You could also check the voltage on each resistor, it should start at 300v on R32 and decrease after each resistor going to the ic.
                    • poweron
                      • May 2019
                      • 371
                      • italy
                      on my card on the line of pin 3 the components are not mounted, as perhaps it is a little different from the scheme
                      • R_J
                        • Jun 2012
                        • 9623
                        That is possible, these schematics are for many different models. If there are no components on pin3 I think the open circuit voltage should be around 4.4v (I could be wrong)
                        I see pin 11 is 0 volts, check the resistance to ground, IF D30 is installed it could be shorted.
                        Another thing to check is C172, If you have a capacitor checkor, check its value, if not, inspect it closely, if it is a square type capacitor and the sides seem to be bulged it is likley bad.
                        It provides a return to ground for the primary of the transformer, if it goes open you would have this result
                        • poweron
                          • May 2019
                          • 371
                          • italy
                          yes you're right, as soon as I connect ac220v to pin 3 I have 4.4v but it goes down a little at a time until almost 0v
                          • R_J
                            • Jun 2012
                            • 9623
                            I believe that is how it should operate, check the other components I suggested. Also check the resistance of the (N2) winding of the transformer and also D3,R70 and any other parts on that line between the transformer and the vcc pin of the ic. If they are all ok, it could be a bad ic.
                            This circuit must work before any other parts of the power supply will turn on.
                            • poweron
                              • May 2019
                              • 371
                              • italy
                              I checked the resistance of N2 about 1 / 1,5ohm C172 is good both in capacity and Q (over 700), at this suspicious point of U2 I tried to look for it but I can not find it online, maybe looking for the card I will be more lucky
                              • poweron
                                • May 2019
                                • 371
                                • italy
                                I doubt, this power supply provides the voltages even if it is disconnected from the main?
                                • R_J
                                  • Jun 2012
                                  • 9623
                                  I don't understand your question. Do you mean if you disconnect the MAIN BOARD from the POWER SUPPLY? Yes the power supply will produce the standby voltage.
                                  • poweron
                                    • May 2019
                                    • 371
                                    • italy
                                    yes you understand the question, I disconnected the power supply from the TV to take measurements, but think of it, the PSU produces the tensions but not in my case, I suspect I am on U2
                                    • poweron
                                      • May 2019
                                      • 371
                                      • italy
                                      I wanted to ask you if it was possible to find, if it existed, the equivalent of U2: FA6A30N
                                        Lithonia Lighting versus Light of America Compact Fluorescent product quality
                                        I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                                        I also have back when Light of America had these light bulbs available for yard lights
                                        The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                                        While the Lithonia lighting fixture has all most certain bulb failure
                                        So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                                        I have only had this light fixture for not more than a year if it...
                                        07-02-2023, 03:45 PM
                                        LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                                        This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-07-2024, 03:40 AM
                                        LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                                        This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-06-2024, 09:10 PM
                                        09-06-2024, 08:40 PM
                                      • serious_electron
                                        Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                                        by serious_electron
                                        Hello Everyone!
                                        I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                                        06-28-2025, 02:57 PM
