Repair LG 60UF770V
  • aidy55
    • Jul 2019
    • 15
    Repair LG 60UF770V
    Hi folks, I bought this tv in 2016 from Very. I don't think it came with a 5 year warranty but Ive sent a repair request to LG to see what they say. Last few expensive AV items have been bought from richer sounds as they seem to do 6 year warranty on everything.
    Anywhoo, this tv has been great past few years and i literally was watching a netflix programme last night, paused it to answer front door, came back and tv was like this.
    It seems to affect only the right half of the tv. The menu displays on the left hand side so I was able to reset tv but no joy. Left it off overnight but still the same this morning...
    Could this possibly be a LVDS cable or mainboard issue. If its the screen I presume i may as well dump the tv.
    This thread shows similar issues although not identical. Ive found a LVDS cable which is only £8. Can anyone provide a link to a mainboard, not sure the cost of those. The fact that tv is perfect one half and terrible on exactly leads me to believe its maybe not the screen but in fact something smaller...
    https://www.badcaps.net/forum/showthread.php?t=66084
    Im not too bad with electronics, never dismantled a tv like this before, is there a repair guide anywhere...
    • 12184
    • U.S.
    Re: Repair LG 60UF770V
    Not sure but tv might be in demo mode, try engine button or some settings button on remote change from demo mode, hit menu for exit.
      • 12184
      • U.S.
      Can try going to: picture settings-picture mode/game settings-scroll down to picture options-turn off all those settings/filters, see if that works.
      • aidy55
        • Jul 2019
        • 15
        TV needs to be in store mode to set demo mode. Buts ive reset it anyway and can confirm its def in home mode. Gaming settings hasn't made any difference. I don't use that mode anyway. Turned off all picture settings in normal mode...no difference
        Ive opened up the tv and taken some pictures so I know if i do buy some parts they will be correct. I plugged out cables and reseated lvds cables but hasn't helped.
        There are two lvds cables, is it possible one cable has affect one side of tv...
        Def seems to be hardware issue...
        • Wilderone
          • May 2018
          • 76
          Swap the 2 flat cables going from the Tcon to panel over & see if it follows.
            • 12184
            • U.S.
            Possibly tab bond issue.
            • Diah
              • Feb 2013
              • 6367
              with all LG TV which working but had issue, the first things we do reset it with IN_STOP command which it will roll back all drivers. reset the TV via normal setting menu its just clear profile of setting. so start with IN_STOP
              • aidy55
                • Jul 2019
                • 15
                Luckily I have a mobile with IR. I got the service remote and done a in stop reset but no joy, still the same.
                I done the test screens, the colours only show up on the good half, does this mean anything
                I have already ordered a lvds cable as it was only £8. Since removing TV from wall is a pain I will do the cable swap test when new cable arrives
                Do I need to swap lvds cables at both ends or just one end.
                • Wilderone
                  • May 2018
                  • 76
                  It's not the LVDS cable you want, it's the flat ribbon cables that go from the Tcon to the panel boards.
                  Swap left for right.
                  See pic for attention,
                  • Diah
                    • Feb 2013
                    • 6367
                    Luckily I have a mobile with IR. I got the service remote and done a in stop reset but no joy, still the same..
                    LVDS not easily got damage unless they broken while wrong reseating them . this you can approve it with good loop to check the end silver pins if any short or Brocken.
                    according to last photo you have issue on MB much its like reflow issue on IC100 or Picture processor in case the LVDS are good and there no damage as i mentioned above
                    • aidy55
                      • Jul 2019
                      • 15
                      Problem is worse now, tv not coming on at all. There is power, standby light flashes red three times but nothing displayed on screen.
                      Does this point to the main board, can't seem to get one on eBay or anywhere for that matter.
                      Thought LG may have got back to me, wonder what they might do for me if anything.
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        Does this point to the main board, can’t seem to get one on eBay or anywhere for that matter.
                        It's the seller not the manufacturer you should be on to, arguing a TV should last longer than a couple of years.
                        I suspect it is a BGA or Processor issue on the mainboard.
                        • aidy55
                          • Jul 2019
                          • 15
                          LG told me to ring Very. Very told me to ring LG. Both not interested. Complained as much as I could. Purchase price was £1099. Tv 2.5 years old. 1 year warranty.
                          LG said new main board £400.
                          I’ve got this lvds cable through, Is it worth replacing?
                          • aidy55
                            • Jul 2019
                            • 15
                            Are you saying I need to swap these wide ribbon cables going down. I thought they were for speakers.
                            Doest look like they can be swapped over
                            • Wilderone
                              • May 2018
                              • 76
                              Yes those wide ones, there will be clips on both panel side & Tcon side.
                              • aidy55
                                • Jul 2019
                                • 15
                                Is it worth leaving in to a TV repair shop. If it is the main board will they be able to repair it without replacing
                                • diif
                                  • Feb 2014
                                  • 6978
                                  • England
                                  I've got this lvds cable through, Is it worth replacing?
                                  Of course Very won't be interested, they are responsible in this case.
                                  A complaint in writing, reminding them of consumer law in this country ?
                                  If you've given up making a claim, I'd ring around first. Some TV repair places just replace boards, others do BGA rework.
                                  • Sevenqi
                                    • Jul 2011
                                    • 292
                                    Try to rework the IC under the big white heatsink, the UF series has the same common issues, or replace the main board.
                                    • aidy55
                                      • Jul 2019
                                      • 15
                                      There isn't a main board available anywhere. Lg quoted me 400 quid can you believe
                                      I've got a decent soldering station with hot air gun. I've used the hot air to solder smd leds but never rework components.
                                      What temp should I be hitting it with
                                      Also my TV doesn't turn on at all ow, standby just blinks a couple of times. I can get a power board for 20 quid
                                      • diif
                                        • Feb 2014
                                        • 6978
                                        • England
                                        There is a reason BGA rework stations are a thing, they preheat the entire board and give a fairly accurate way to follow the reflow temperature profile evenly over the entire processor.
                                        With the board being £400 and as rare as unicorns second hand, perhaps consider getting a professional to reball your board.
                                          Lenovo ThinkPad L13 + 3YOS Warranty Notebook L Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad L13 + 3YOS Warranty Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L13 + 3YOS Warranty boardview and L13 + 3YOS Warranty schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 04:30 AM
                                          Lenovo ThinkPad L15 + 3YOS Warranty Notebook L Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad L15 + 3YOS Warranty Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L15 + 3YOS Warranty boardview and L15 + 3YOS Warranty schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          Lenovo ThinkPad L13 Yoga + 3YOS Warranty Hybrid (2-in-1) L Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad L13 Yoga + 3YOS Warranty Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L13 Yoga + 3YOS Warranty boardview and L13 Yoga + 3YOS Warranty schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
