Samsung 65MU7350 problem
  • Diah
    • Feb 2013
    • 6598
    Re: Samsung 65MU7350 problem
    i said when it power on keep press power on the TV side panel to put it in stand by mode
    • freeman3020
      • Jun 2019
      • 30
      • Palmo
      i did as you said
      • Diah
        • Feb 2013
        • 6598
        try again.. you need to put the TV at stand by mode
        • freeman3020
          • Jun 2019
          • 30
          • Palmo
          i tried more and more , TV not go to standby , only if disconnect screen two cables i can go to standby, then i tried , after connect cable TV power up and repeat restarting
          • Diah
            • Feb 2013
            • 6598
            it look bad news.. but let do this..
            plug it out from wall socket.. and plug the LVDS only from MB side.
            take out the PWB out. and the MB too. discharge all Caps on the PWB start from hot area the main big caps and to the cold area.. all caps.. by shorting the pins pf caps +&-
            also please post clear high resolution photo on the MB of the down side. waiting for your photo and the discharge process
            • freeman3020
              • Jun 2019
              • 30
              • Palmo
              #26
              i did as you told me discharge cap and connect main board TV switched on and stay on and can here sound but no picture , when switch off then on by remote its back to repeat booting
              forum reduce resolution
              • Diah
                • Feb 2013
                • 6598
                common man.. my post #21 and early i said we need your TV to be in stand by.. so you after discharge and the tv stay on with out picture and you can turn it stand by... why you don't stop and replay here the result before you do as you like... sorry,, at this point i cant help. its beginner fault replace power board and brought it back to the set with out discharge
                • freeman3020
                  • Jun 2019
                  • 30
                  • Palmo
                  #28
                  sorry but i don't understand,, i disasmble power supply out and discharge capacitor , then plugged it on TV with all cable connected and switched TV on without picture so you mean now hold power switch for second to go to standby ????
                  whats next?????
                  • Diah
                    • Feb 2013
                    • 6598
                    when you discharge PWB all caps you had the TV turn on with sound and respond to remote control with out picture. when you turn it off and on again start restarting
                    this mean
                    1- you have broken line on discharge at panel or LVDS
                    2- if you can do it gain and put it in stand by mode and direct to switch it to service menu. the screen could come back.
                    3- you had spark at MB after you brought PWB back to the set with out discharge
                    4- the TV now at setting sound only as point 2
                    • freeman3020
                      • Jun 2019
                      • 30
                      • Palmo
                      #30
                      this mean
                      sorry as i understand if i get TV on standby mode with cables connected then use my remote control by press info->menu->mute then power the TV will got picture??
                      • Diah
                        • Feb 2013
                        • 6598
                        badcaps.net hat many good knowledge members more experiences than me.. with other mother language too... please advice yours prefer language to let them join your problem. to me its out.. sorry
                        • freeman3020
                          • Jun 2019
                          • 30
                          • Palmo
                          #32
                          sorry man ,but step by step we can understand us, don't be angry and sorry again , i will try again to put TV on standby mode , but is the service menu solve no picture problem????
                          • Diah
                            • Feb 2013
                            • 6598
                            i got yours PM. i am not angry at all. we are here just for help. but who seeking help need to follow all tests and replay with out doing other things which it may caused more damage.
                            also take out the metal shield of the Panel TAP and post photo of both side left and right. hope your TAP on each side are made of 3-4 pieces connected via ribbon joiner and not as one piece.
                            • freeman3020
                              • Jun 2019
                              • 30
                              • Palmo
                              #34
                              i found the problem it's in COF one of its have burned point and disconnect quarter of Panel TAP and TV work , 3/4 of picture
                                Too bad the panel went out.
                                  09-07-2024, 05:50 AM
                                • howardc64
                                  Samsung UN55JU650DF network/streaming problem
                                  by howardc64
                                  Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                  This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                  07-09-2025, 12:44 PM
                                • rayfloyd170
                                  Samsung BN44-0851A powersupply problem
                                  by rayfloyd170
                                  My 40 inch Samsung TV suddenly went off.
                                  I check the powersupply and has blown fuse. I checked the bridge rectifier and found shorted so i removed it but it was good out of the board. I noticed the Mosfet K10a60w was shorted and i replaced it. Also checked the output diodes and found 2 in parallel shorted. I removed both legs and determined only 1 of them is shorted hence i replaced it.
                                  I tried to plug it and good the fuse did not blow. I get 310V from the primary caps. However i dont get any voltage from the secondary output.
                                  What could be the problem...
                                  04-26-2022, 10:37 PM
                                • alro7779
                                  Samsung UN55MU6103F video problem; has colored stripes on the display
                                  by alro7779
                                  Hello, everyone!
                                  A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                  09-27-2025, 11:29 PM
                                  09-06-2024, 11:40 PM
