Samsung 65MU7350 problem
  • freeman3020
    • Jun 2019
    • 30
    • Palmo
    I have problem with my new samsung TV 65MU7350 suddenly its switched off then i tried to power it up again , only backlight switch on the off and continue in this repeat boot without any picture on screen , i have worked tv 65NU7100 , i took powersupply with same connector for mainboard and put it on MU one without connect backlight because connector different ,also TV not turn on
    i return powersupply to working TV , now its not work its boot on repeat loop only backlight
    what's this mean?? there is pin on power supply named fail count, is this mean power supply have eeprom to store fail and how to bypass this?
    attached board of MU7350
    Re: Samsung 65MU7350 problem
    What are the P/N for each one of the power supply board? BN44-?????
    • freeman3020
      • Jun 2019
      • 30
      • Palmo
      i think its not problem with power supply, main board need to reset?
      i tried to reset flash and eeprom , i don't know what's flash using for? i shorted firstly upper flash with shorted nreset with sda , then tried with eeprom same method.
      is this wrong?
      My local service repair same problem without change any board , then its reset problem as i think
      • freeman3020
        • Jun 2019
        • 30
        • Palmo
        bn44-00932A
        • freeman3020
          • Jun 2019
          • 30
          • Palmo
          when disconnect screen 2 ribbon -i can hear sound when use remote and backlight still
          on !!!
            So both power supply are BN44-00932A?
            They cannot be the same since in your post #1 you said "i took powersupply with same connector for mainboard and put it on MU one without connect backlight because connector different"
            And "i return powersupply to working TV , now its not work its boot on repeat loop only backlight" so the working TV is also not working now or what, it is confusing.
            We also need the pictures of the whole back side of the TV showing all the board.
            If you disconnect the cable between the main board and the power supply board, do the backlights come on and stay on as long as the Tv is plugged into the AC outlet?
            • freeman3020
              • Jun 2019
              • 30
              • Palmo
              so now i have NU one only , First screen repaired ,technician repaired it without soldering or changing board, how?
              when disconnect main board , yes back-light work ,and when disconnect 2 ribbon cables from screen , screen work with sound and not turn off, the problem now , when connect screen "Glass" turn on then off without picture and repeat this loop
              can you explain to me the flash rom with label t-con for what? i rest it by short nreset and sda .is it erase any thing?
                That indicates problem on the panel itself which can be as simple as shorted caps on the tab bonding board or worst case will be the shorted COF.
                • freeman3020
                  • Jun 2019
                  • 30
                  • Palmo
                  but screen worked before take power-supply from it and main board not removed
                    I do not know what else to tell you.
                    BTW, you are talking about the ribbon cables between the T-CON board and the LCD panel, correct?
                    May be you should show the pictures of the whole backside of the TV showing all the boards.
                    • freeman3020
                      • Jun 2019
                      • 30
                      • Palmo
                      thank you but it's secret in 2017-2018 version , hope to find solution
                      there isn't T-con board, ribbon from tab bonding board to mainboard
                      • Diah
                        • Feb 2013
                        • 6435
                        your first TV 65MU7350 was SPI Flash firmware which they flash it again on the eeprom.
                        yours second TV 65NU7100 which you used the PWB to test your first one. you said the plug from PWB to MB are same.. this is not true. the size & type are same but the PIN may not same assignment. so post photo on yours 65NU7100 PWB especially on the socket to compare it with yours first post photo.
                        • freeman3020
                          • Jun 2019
                          • 30
                          • Palmo
                          now forget 65MU7350 , technician repair it without soldring any thing it was same problem of NU , now i need to repair NU one by my self
                          for pic you request ' im sure its same pins
                          • Diah
                            • Feb 2013
                            • 6435
                            okay.. the pins are same. yours 65NU7100 had T-CON its on the panel Tap installed. the cable you disconnected from MB to Panel are LVDS. not ribbon .
                            you did short contact on the MB?
                            try to reset the LVDS again. and tell if you can put the TV in stand by mode
                            • freeman3020
                              • Jun 2019
                              • 30
                              • Palmo
                              i did't make any short on MB, how to rest LVDS?
                              • Diah
                                • Feb 2013
                                • 6435
                                reset it mean plug them out from both side and plug them back again .
                                also plug out the TV from wall socket.. keep it out foe awhile.. then press power on the TV side panel.. keep press then plug it back to wall socket.. keep press the power until the LED indicator changed to RED color
                                • freeman3020
                                  • Jun 2019
                                  • 30
                                  • Palmo
                                  i unplugged cables any wait 10 minutes ,, where is t-con on this board
                                    So the panel has integrated T-CON.
                                    • Diah
                                      • Feb 2013
                                      • 6435
                                      need to take out the metal shield to see the T-CON chip leave this point and inspect LVDS the silver pins from both side to be sure all are in place and not one broken.. then replace them back and do the power as i explained
                                      • freeman3020
                                        • Jun 2019
                                        • 30
                                        • Palmo
                                        these cables not disassembled before , but also i removed metal shield and checked no problems on any cap , and i plugged it again , same problem back light switch on and here start sound then restart without any picture on screen
                                          09-07-2024, 05:50 AM
                                        • howardc64
                                          Samsung UN55JU650DF network/streaming problem
                                          by howardc64
                                          Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                          This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                          07-09-2025, 12:44 PM
                                        • rayfloyd170
                                          Samsung BN44-0851A powersupply problem
                                          by rayfloyd170
                                          My 40 inch Samsung TV suddenly went off.
                                          I check the powersupply and has blown fuse. I checked the bridge rectifier and found shorted so i removed it but it was good out of the board. I noticed the Mosfet K10a60w was shorted and i replaced it. Also checked the output diodes and found 2 in parallel shorted. I removed both legs and determined only 1 of them is shorted hence i replaced it.
                                          I tried to plug it and good the fuse did not blow. I get 310V from the primary caps. However i dont get any voltage from the secondary output.
                                          What could be the problem...
                                          04-26-2022, 10:37 PM
                                        • alro7779
                                          Samsung UN55MU6103F video problem; has colored stripes on the display
                                          by alro7779
                                          Hello, everyone!
                                          A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                          09-27-2025, 11:29 PM
                                          09-06-2024, 11:40 PM
