samsung power supply
  • Marty Fredericksen
    • Jun 2019
    • usa
    Could someone tell me what output voltage I should see from a samsung led tv power supply board. tv model un50j6200afxza, board #bn44-00772a. Currently I am seeing 2.4, 2.4, 2.4, 2.4 and 0 vdc on top 5 pins and 0, 0, .8, 0, 0 on lower 5 pins. Tv will not power up an no standby light. Thanx for any help available.
  • R_J
    • Jun 2012
    • 9628
    Re: samsung power supply
    all the information should be printed on the board, check the voltage on JP817
    The first thing you need is standby voltage, without it you will have nothing.
    The plugs have numbers IE: CNL802, and pin numbers are identified, pin 1 D+
    CNM803 pin2 A13V, pin6 PS_ON etc.
      03-31-2024, 02:12 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      07-01-2024, 06:34 AM
    • stylishconsultant
      un60j620dafxza - Samsung No Display Problem
      by stylishconsultant
      Hi All,
      Need help.
      I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
      So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
      problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
      might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
      09-04-2024, 03:26 AM
    • cheeky2
      Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
      by cheeky2
      This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
      I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
      Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
      06-15-2025, 05:12 AM
