Problem with my Plasma TV LG 50PB560B
  • Le Fils du Boulanger
    • Feb 2019
    • 18
    • Gabon
    Good evening, I have a plasma TV LG 50PB560B that did not light anymore. There was just the red LED on when I turned it on. I suspected the Y-SUS card. Indeed, controlling, I found a transistor 30F133 shorted. I replaced it with IRG7R313U. When I turn it on again, the screen lights up and then stops almost every second and it's repeated. No OSD display, no sound either. The voltage Vy oscillates between 0V and 5V. Here are the few pictures of the TV that I could take.
    Thanks for your help.
    • Feb 2019
    • 18
    • Gabon
    Re: Problem with my Plasma TV LG 50PB560B
    Photos of the back of the tv
      • Feb 2019
      • 18
      • Gabon
      Thank you for your help please
      • theone111
        by theone111
        3. Problem: TV shuts down
        07-22-2024, 10:36 AM
      • renech
        panasonic TH-42PC77U plasma television half screen problem
        by renech
        hello,
        I hope someone on this forum can assist me.
        I have a panasonic TH-42PC77U plasma television.
        the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
        i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
        I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
        I have read some posts that suggest the problem is related to the boards on the left...
        12-12-2022, 06:53 PM
      • Zeonalbasta
        Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
        by Zeonalbasta
        i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
        The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
        09-13-2024, 01:17 PM
      • Gibon378
        Problem with stopping audio and video for no reason
        by Gibon378
        PC Specs:
        • CPU: Ryzen 5 1600
        • GPU: GTX 1080 Palit JetStream
        • MOBO: ASRock ab350 PRO4
        • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
        • PSU: XFX 650W (don't remember what model)
        • OS SSD: ADATA SP920
        • OS: Windows 10 21H2
        Problem description:
        Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
        11-19-2022, 09:41 AM
      • perzyk23
        Lenovo T580 - LCD Panel problem - error 0288
        by perzyk23
        Good morning,
        I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
        10-25-2024, 12:42 AM
