Jvc Lt55N930 model no power on
  • fayal
    • Jan 2015
    • 14
    • uk
    Hi all please need dump jvc Lt55N930
    thanks.
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Jvc Lt55N930 model no power on
    Did you try tv JVC tv reset process?
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • Andreas_de
      Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
      by Andreas_de
      Hello!
      i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
      Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
      Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
      04-12-2025, 10:38 AM
    • reessi
      HP - CE Series - DAG7ALMB8C0 REV.C - MODEL - G7AL-2G - Missing MAINON & SUSON - Turns on power LED & Charges
      by reessi
      I have re-soldered the loose pins on the RAM slot which is a common fault on these models..
      It charges and turns on the power LED but is missing several voltages like RAM and CPU do not come up which I believe is due to MAINON & SUSON being missing to turn these supplies on..
      What I am un-sure of is what is the ITC chip waiting for to send out these signals, what are the requirements?
      I have checked these lines in diode mode and they seam normal -> 600.
      I have checked to see if they come on for even a fraction of a second...
      07-15-2025, 09:14 AM
      03-31-2024, 02:12 PM
