Samsung PS60F5500 TV - Sound but no picture
  • ispot13
    • May 2019
    • Netherlands
    I have a PS60F5500 TV and suddenly it's no longer working. The TV does respond to the IR and I can blindly select the correct HDMI source and when done I hear TV sound. The display stays black.
    So I opened up the TV and measured the VS and VA on the power supply. Both were way of the normal value. VS was only 10V and VA was 0V.
    So I measured the VS-ON signal and noticed that one stays at 0V too. So the main board seems to be broken, right?
    Someone told me I could try disconnecting VS-ON from the main board and then connect VS-ON to a 5V power source for a test. The guy stated that this should bring up the VA and VS power and possibly bring back the picture.
    So I tried that. I cut the VS-ON cable and connected the VS-ON pin to a 5V source on the power board and turned on the TV.
    The TV behaved exactly the same as before. I can still hear the audio and it does respond to IR etc... The screen still stays black as if nothing has changed.
    But the power on VS and VA were there. VS at 208 volts and VA at 58 Volts.
    What do you guys think could be the issue here?
  • TR103
    by TR103
    - it keeps rebooting
    01-22-2025, 04:12 PM
  • Mgiffune
    by Mgiffune
    06-09-2024, 10:28 AM
  • Ierwin
    by Ierwin
    05-13-2025, 03:31 PM
  • jchang
    Samsung UN70NU6900F no picture and no sound
    by jchang
    Hi all
    I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
    Symptom:
    No picture no sound.
    When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
    No sound at all.
    What I tried:
    1. I tried unplugging the left or right ribbon...
    01-09-2023, 06:28 PM
  • Dodgethis
    Samsung QN75Q6DRA, No Picture, Has BL, and Sound
    by Dodgethis
    Hello all,
    This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
    09-11-2024, 07:39 AM
