lcd tv SAMSUNG LE40R71B not work ,relay clicking
  • ANDRASONI LUCIAN
    • May 2012
    • 56
    • Romania
    I have this TV equipped with the source BN44-00134A.Tv does not start, it is heard how the relay is continuously coupling and disconnecting. The stable voltage drop is STB = 6.5V, P-ON / OFF varies between 0.2-2.5V in normal operation = 2.6V) PFC between 360-385V (when going is 382V). All electrolytes, secondary-primary, have been changed, except the 220uF / 450V which is ok. In this state, if measure the voltage on the pins 1-2 to optocouplePCS802, the relay stay connect and tv work normally . I have replaced the PCS802,801, the ICS 802 (KIA431), the QP803, the QS801, the QS802 checked. If I stop it restart (unplugged) in a few minutes, it works normally, if I leave it a little longer, the defect returns. Any suggestion is welcome, I do not think it would be the problem mainboard. Thank you!
    I attach the power supply+ inverter schematic model BN44-00134A
    • 12274
    • U.S.
    Re: lcd tv SAMSUNG LE40R71B not work ,relay clicking
    Try a reset and or firmware update, might not fix it but won't hurt any.
      • 12274
      • U.S.
      Test connector from mainboard to powerboard on powerboard side with all boards hooked up, test with tv plugged in but off then hit power, report both conditions here, give pin number, pin description/name and condition on and off.
        • 12274
        • U.S.
        Could try heating mainboard with hairdryer, small section at a time be sure n heat the capacitors on mainboard too and see if there's any change.
        • ANDRASONI LUCIAN
          • May 2012
          • 56
          • Romania
          Thanks for the reply, I reset, but nothing has changed. When it normally works the voltages are the ones written on the board and when it does not go (the relay click) the only correct voltage is STB (stand by) = 6.44V
          • R_J
            • 9588
            Check and resolder all the transformer pins and also any of the fets/diodes etc mounted to heatsinks, I would start with this.
            Sometimes these similar boards can also have the relay contacts go bad and cause NT801 to fail.
            When power on is applied the relay contacts will short out NT801, if they don't the power supply will not operate properly.
              1) The stby Voltage is 5.4V not 6.4V.
              2) You can run the power supply board by itself (you must disconnect the cable going to the mai board first) and force it on by using 1K resistor between 5.4VSTBY and the P-ON/OFF pin, it should then come on and stays on with all the Voltages present.
              If the 5.4V stby is steady then I suspect bad main board that is sending out steady PS-ON signal.
              Pictures provided by shopjimmy. BN44-00134A.
              • ANDRASONI LUCIAN
                • May 2012
                • 56
                • Romania
                On the CNM801 coupler, pin 2, the voltage STB = 6.5V, see schematic diagram...,
                anyway solved by replacing the eeprom 24C32 (IC903) with empty memory (FF). Thanks!
                  09-07-2024, 05:50 AM
                • Journey11
                  Samsung TV won't turn on ... keeps cycling the power relay on & off
                  by Journey11
                  Hi All,
                  First time posting here ... my name is Kevin but my friends call me Journey.
                  I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
                  After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
                  It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
                  07-04-2024, 02:44 PM
                  09-06-2024, 11:40 PM
                  09-06-2024, 08:40 PM
