TC-P50G10 14 blinks
  • Spector
    • Oct 2018
    • 17
    TC-P50G10 14 blinks
    For starters I'm pretty noobish so be patient.
    I have a Panasonic TC-P50G10 that the screen powers on for a quick second, and then off. The power LED then blinks 14 times.
    I've been googling, and it appears that this must be rather unusual as every sing "14 blink" issue I see is for a different model of TV (2011). The same goes for the search function in this forum.
    I also have attached the service manual, which has no mention of 14 blinks (only up to 13).
    If nothing else, at least it's interesting.
    I've looked at "A" boards as that is where it would point on the newer models, but that appears to be the common failure point on these TVs since anyone who thinks they have a working on wants over $100 for them.
    Tomorrow I intend to try applying a bit of heat to the chips on the A board to see if it's a BGA or bad chip problem.
    In the meantime, I'm all for suggestions on where to start. I only spent $15 on this TV so if it's not worth the trouble that's not the end of the world either.
  • Demonata08
    • Jan 2019
    • 116
    Re: TC-P50G10 14 blinks
    Been working on a similar model myself. Theyre a pain. Its almost certainly a bad A board. You can test its error detection by trying to get different errors to pull up.
    Pull the power from the SS board and see if it reverts to an 8 blink. If it does plug it back in and unplug the buffers from the sustain. You should get a 7 blink.
    If it does those then theres hope
    Also perhaps if it powers up your reading the blinks wrong and it is a 13 blink. I had the same issue reading mine is why i say that. It should cycle through blinks. So let it cycle and count very carefully
    • Spector
      • Oct 2018
      • 17
      It's certainly possible that I'm just misinterpreting a 13 blink. The way the service manual reads, it would have 13 blinks and then a gap and then another blink. But if there's no pause between them then it would look like 14 blinks.
      Thank you for the advice.
      The more I research, the more it seems like the A board is a common issue with these models.
      • Demonata08
        • Jan 2019
        • 116
        Yep. very common. Also the SS board is pretty common also. but theyre pretty expensive to come by.
        • R_J
          • Jun 2012
          • 9624
          It is 13 blinks then a pause and it starts the count again, they just did'nt have room to put another 13 pulses on the page
          Look at the other error pulses, they repeat then run out of room in the chart
          • cloo
            Panasonic ZT60 plasma tv with strange behavior and 8 blink code
            by cloo
            I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
            It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
            So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
            After doing a factory reset this problem was gone and the picture was back to...
            01-06-2025, 06:02 AM
          • EazyBone
            Un50cu7000 2 blink oddity *partially solved
            by EazyBone
            I write this to maybe help another with this TV.
            So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
            The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
            03-18-2024, 10:24 PM
          • Nairolf
            Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
            by Nairolf
            I have a Samsung DM32D display.
            When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
            Here’s what I have tried so far:
            1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
            2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
            3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
            From these tests, I suspect the problem might be on the mainboard. Could anyone...
            08-24-2025, 03:47 AM
          • Vebririon
            panasonic TX-P50V10E 6 blink led problem
            by Vebririon
            I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
            Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
            I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
            05-17-2025, 10:16 AM
          • Userrrname
            Tx-pr42gt30 6 blink
            by Userrrname
            👋🏻I recently got a tx-pr42gt30, I bought it in non-working condition. When I opened it, I saw that all the transistors and diodes had been removed from the tnpa5330, and several microcircuits were in poor condition, so I decided not to try to repair it. Instead, I bought another tnpa 5330 (also AB), which was already repaired (according to the seller, the board was repaired and worked before the screen was damaged), transistors were also changed on it, but Chinese copies were installed (there is no round hole in the middle, the inscription is easily erased) and a pair of transistors that...
            07-19-2025, 07:53 AM
