Element elefw605 power issue maybe?
+ More Options
Latest Activity
  • R_J
    replied
    Re: Element elefw605 power issue maybe?
    Pictures of the power supply trace side
  • Demonata08
    replied
    Originally posted by budm
    The TV of OP in that link uses completely different boards than you TV, OP's TV in that link uses PHILIP/MANAVOX/EMERSON boards which are know for having shorted out caps on the main board.
    Yeah i noticed that. But i figured the resistance check might help anyways.
    Im not really sure what the next move could be..i did notice if you look in the right under the power plug on the main it has two test points that say 5v and 12v. 12v is there. 5v shows nothing but im positive its there on the pboard
    On the back theres more test points. A 3.3v and a 1.8v both are there
    replied
    Originally posted by Demonata08
    musta missed that one. I followed the advice on checking the resistances. I'm really not sure i'm doing it right. i have the meter grounded to the chassis and im just doing a simple resistance check on the pinout this is the results.
    5v .45k
    5v .45k
    PS_ON 20k
    5vsb 20k
    12v 1k
    the ps_on and 5vsb are weird. they start in the millions and they just keep going down or they start in the thousands and keep rising. the other ones are stable and dont move.
  • Demonata08
    replied
    on the main or power? I can try to get a good clear picture
  • R_J
    replied
    It does'nt look like there are any problems on your board, I think they had a cap that was shorted or close to being shorted. You can't really rely on resistance checks, there are caps and resistors etc. in the path that can effect the readings.
    without a schematic or good clear view of the traces I don't know how to trace down the fault.
  • Demonata08
    replied
    Originally posted by R_J
    Did you look at this thread? the power supply is different but maybe the main board is the same, he had an issue with some caps on the main that might be causing the problem https://www.badcaps.net/forum/showth...light=elefw605
    5v .45k
    5v .45k
    PS_ON 20k
    5vsb 20k
    12v 1k
  • R_J
    replied
  • Demonata08
    replied
    How would WHAT work? It likely won't make the tv work, but if you find a suspect cap, you can replace it and then see if the standby stays at 5 volts.
    If you want to check the power supply properly you need to have a scope and an isolation transformer so you can trace the fault in the primary. Or you could use a cap esr meter to check the caps to rule them out.
    All the caps checked out except maybe one. Some of the 10uf 50v smaller caps were showing around 1 esr.
    The bigger 450v 80uf was showing 5esr so i went ahead and replaced that. It still has the same problem but the buzzing i was hearing is drastically reduced now.
  • R_J
    replied
  • Demonata08
    replied
    Monitor the 5v standby pin and try heating some of the small electrolytics on the primary side and see if the voltage comes up a bit, this power supply might be operating in burst mode while in standby and it could just be one of the feedback run caps is weak. these small 1~10µf caps never look bad but can dry up and goe basically open
    The standby voltage must be there to operate the microprocessor so it knows that you pushed the power button. The power button connects to the micro and the micro issues the Power On command to the power supply
    I will do that. But how would that work if the tv is automatically trying to turn on when its plugged in
  • R_J
    replied
  • Demonata08
    replied
    If you disconnect the cable from the power supply board to the main board, what do you get on the Standby +5SB pin? That is standby power supply that is always running to supply the power to run the main board. Standby Voltage will always be present as long as there is AC feeding the TV. No standby Voltage then the rest of the switched power supply will not be on since there will be no Voltage to run the main board so the main board cannot send out the PS-ON signal, that is why it is quiet.
    The main board requies the +5VSB to keep the board alive so it can receive the ON command signal from the remote or from power switch, the TV will also remember the last power state when it lose AC power.
    BTW: "Its very confusing to me that 5vsb would be there at all if its not in standby." I do not understand what you mean. You do not expect Voltage at the +5VSB pin if the TV is NOT in standby?
    Sorry for the triple post but now i have an idea. If what you said is true and the board requires the 5vsb at all times but when its under a load it drops to 3.3 is that not a power issue then. Which might be the source of the buzzing?
  • Demonata08
    replied
    https://www.badcaps.net/forum/attach...5&d=1558240639
    BTW, the BL-ON only shows 0.35V, is that right when TV is working? You do see the backlights come on, correct?
    How about the Adj (dim) control signal?
    I have not seen the tv come on at all since it last went out. The problem was getting progressively worse and i suppose the last time it was turned off was it for it. If i have patiences i can unplug it a bunch of times will hitting the power button and it might come on. But its not a fix. Next time it goes off itll be in the same situation
  • Demonata08
    replied
    No because this tv is never in standby. As soon as you plug it in it gives the signal to turn on. But the backlights dont turn on or anything. Just the voltage from the pboard shows it to be on.
    The only way i can get it to standby is unplugging the main. In which it shows 5vsb as 5vs. With the main plugged in it shows 3.3v on 5vsb. Im not experienced. I was just commenting on how i figured thr 5vsb would not be there if the tv wasnt in standby.
    replied
    replied
    Quick update. I took out the 5vsb pin from the ribbon and plugged it in. Sure enough the power supply is quiet. Whatever the problem is im pretty sure its on that line.
    Its very confusing to me that 5vsb would be there at all if its not in standby. But instead something brings it to 3.3v
    replied
    See post #30.
  • Demonata08
    replied
  • Demonata08
    replied
    Are you sure you did not get the PS-ON and the 5VSB pin mixed up? More likely the PS-ON is 3V and the 5VSB is 5V because all the Voltages are generated by the same transformer, the +5V (swithed +5V) is the same +5V that is fed to the +5VSB, it is just being switched that all. The main board cannot be sending out +5V to the PS-ON pin if the +5VSB is only 3V for running the main board.
    Unfortunately im quite positive of my reading. I did test my theory that the set is trying to turn on as soon as its plugged in and that does seem to be the case. I unplugged the main and all voltages were 0 basically except +5VSB which was now 5vs
    replied
  • GLISIT
    by GLISIT
    01-16-2025, 02:29 PM
  • justice171
    Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
    by justice171
    I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
    Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
    1. Verified that all critical voltages are present:
      • 3.3V and 5V are always present if DC is plugged.
      • 1.8V on the BIOS chip is present.
    2. Checked the power button functionality:
      • When pressed, the voltage drops to 0V, indicating the button is functional.
    3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
      • Confirmed connectivity is intact, ruling out issues
    11-26-2024, 12:39 AM
  • claws77
    lenovo flex 5 14itl05 power sequence issue
    by claws77
    hi guys, my motherboard will not start no matter what
    when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
    but rest nothing happens no sign of life.
    this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
    with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
    but now nothing happens no matter how much i wait/ charge/ press and hold power button.
    i have no knowledge of motherboards ....
    10-20-2024, 02:48 PM
  • SuperJames
    Dell G3 17 3779 Weird power cycling and shutdown/restart issue
    by SuperJames
    This one's a weird one, and still unsolved despite it having gone back to Dell once.
    Specs
    i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
    Backstory
    I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
    10-23-2023, 04:09 PM
  • Soulzink
    Samsug washing machine. Power supply DC41-00189a board issue
    by Soulzink
    I am trying to fix a samsung washinmachine power supply main board.
    I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
    Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
    The power supply board reference is the following: DC41-00189a
    I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
    04-19-2025, 06:26 AM
