panasonic TC-P65ST30 8 power led error code
  • nwelec
    • 61
    • usa
    TV has the 8 LED error code. This normally means the SS board is bad. If I follow the service manual and disconnect ss11 it still has the 8 error code but if I remove the cable to c23 from the ss board the tv has no error code and the tv stays on. Does this mean that the C2 board is bad or could it be the panel. I did check for continuity between pins 1 and 2 of ss61 and ss66 and they were fine.
  • R_J
    • 9588
    Re: panasonic TC-P65ST30 8 power led error code
    I suspect one of the cof is bad for the panel. Try disconnecting each of the connectors between the C2 and panel and see if it will stay on and give a picture (with black bar at disconnected plug)
    • nwelec
      • 61
      • usa
      I will try that, thanks.
      • nwelec
        • 61
        • usa
        I tried what you suggested and still same issue. I guess maybe c2 board is bad.
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • Curtissimo
          HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
          by Curtissimo
          Hi everyone.
          I have a HP Elitebook 850 G8.
          Serial: 5CG2324XM0
          ProdID 6L8D5EC#ABA
          It has a Winbond W25Q256JVEN Chip.
          I need to remove BIOS Password.
          I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
          Attached my dump.
          I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
          I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
          What I did:...
          08-26-2025, 04:42 AM
        • Sus256
          HISENSE 65E7KQ PRO - no boot
          by Sus256
          Hi all!
          HISENSE 65E7KQ PRO
          RSAG7.820.13512 - chassis
          MT9618BAATAB - cpu
          RSAG7.820.12059 - power
          HD650Y3U77 - panel
          KLM8G1GETF - emmc
          The TV does not turn on, the standby indicator is on. All voltages are present.
          Emms is dead. Not readable, not detected.
          Replaced emmc.
          But with another dump there is no launch
          Terminal log
          UART
          AC_ON
          RPMB key is not yet programmed
          HASH1_VERSION=0x00000000 64bit
          E-B
          FDE enabled
          layout pattern onebin by SAR7,0...
          06-01-2025, 02:11 AM
          by sam_sam_sam
          03-31-2024, 02:12 PM
