Help With Bad Cap ID on LG M208WA
  • pagy snv
    • Nov 2009
    • 4
    Re: Help With Bad Cap ID on LG M208WA
    Hello dear friend,i find all so the service manual from this LCD monitor but there was nothing about power supply in it.When you have some schematics from this power supply please send it to me.I will be very happy.Thank you in adwantage.Bye.
    ps.my email:peter.pagacik@gmail.com
    • softicicle
      • Jul 2009
      • 14
      Hello peter,you are right,there is no information about the power supply in the service manual.There is no schematic available for the power supply,but i have found the LG part number : 6871TPT318G .Are you polish ? ,the psu is available to buy at north.pl
      http://north.pl/karta/6871tpt318g-mo...5,9759800.html
      I can`t find my psu at the moment, sorry.
      • pagy snv
        • Nov 2009
        • 4
        Thank you my friend i am Slovak,i find it in one electronic web shop in Slovakia for 25 Eur.Bye
        • Sraros
          LG Flatron M208WA vertical purple stripe
          by Sraros
          I have this TV-monitor out of a sudden appeared a vertical purple stripe.
          I checked voltages on the main board, all fine. Cleaned and reseated the cable to the panel board but nothing. Is there a chance to be fixed or send it for recycling?...
          01-06-2021, 04:04 PM
        • howardc64
          UN75RU800DFXZA FA01 CA02 Compatibility
          by howardc64
          Got a CA02 version without all the boards. LCD panel not cracked but unknown condition. Backlight seems to work with LED tester.
          Board sets cost 2/3 price of the TV. Found a FA01 version board set for good price. ShopJimmy doesn't show FA01 CA02 as interchangeable. main board numbers between 2 versions are different but t-con to panel connection appears identical. LCD panel PN is 1 letter different.
          Version CA02
          LCD = CY-NR075FGHV1H (letter H)
          main = BN94-14163F (shopjimmy link)
          Version FA01
          LCD = CY-N...
          01-01-2024, 12:36 PM
        • Iceking007
          Help With Identifying A Fuse (? I Think)
          by Iceking007
          I'm posting this here because I didn't see an "(Help) Identify(ing) Components"/ "Components (Information)" etc. Thread.
          I'm repairing a brushless DC motor board, nothing critical just a simple power board. One high side Mosfet and one low side Mosfet were found short (cross phases), and I didn't have continuity through the positive supply. Found two components that were not conducting. Their appearance was similar to capacitors, however they contained some writing, and they were online with the primary power bus. So I determined they were...
          07-27-2024, 01:52 PM
        • piernov
          Beginner's guidelines
          by piernov
          You have a laptop that does not power on, powers on but shows no image, crashes, etc… You want to fix it but you don't know where to start.
          There are 2 situations:
          1. You just want your laptop fixed
          2. You want to learn about fixing laptops
          Sorry, but if you're in situation number 1, we recommend you to use the services of a trustworthy professional repair shop.
          Unfortunately, if you're not serious about learning, you will waste your time and money, and you will make us waste our time as well.
          If you are in situation number 2, then please continue and...
          09-20-2020, 09:46 AM
        • Nikolai Danylchyk
          Lenovo T480s usb-c charging port replacement - Knocked off a couple of diodes.
          by Nikolai Danylchyk
          Hi folks. As the title says, I was doing a port replacement on a Lenovo Thinkpad T480s and in the process of post-solder cleaning, I somehow knocked off 2 or 3 diodes (i think they are diodes) near the main usb-c. I can't seem to find what kind of a diode is that. I know it's ultra tiny and just has a letter "G" on it. Would someone maybe have a proper schematic for the t480s model? I can only find the non-s one and it's quite different to the "s". Would love to figure out what component that is.
          Thanks in advance!...
          05-08-2025, 06:18 AM
