Sony OLED TV 4 red blinking lights
  • ransome
    • Nov 2013
    • 20
    • usa
    I have a couple of sony oleds that will work for a bit then shut down and start blinking red 4 times on the bottom. These tvs have thin lines that are probably shorting the panel.
    Any fixs
    Thanks Gregg
    xbr65a1e
    xbr65a9f
    xbr65a8f
  • Diah
    • Feb 2013
    • 6411
    Re: Sony OLED TV 4 red blinking lights
    could you show us here photo of one of them with this thin line ?
    you can located it on the ribbon if its on No 1.2.3 or 4 and with tape hide the suspected line by measure how many line at each ribbon X4 and measure the distance of the line location on the nearest side of screen to know which line or at least with couple of line... then check if the set keep on with black line on screen
    • ransome
      • Nov 2013
      • 20
      • usa
      Here are 2 pictures of different sets with lines. One is a white line on the right side the other is a black line one third of the way to the top.
      I understand that the lines probably can't be fixed as it is in the panel but it would be nice if the tv tv could stay on..Has anyone ever successfully repaired the four blinking red lights on an oled sony
      thanks Gregg
      • Diah
        • Feb 2013
        • 6411
        you need to do good visual inspection for both of any transport damage . the panel are LG brand and which serial No.?
        one last things to test those sets its always recommend with Video via HDMI or USB pen, or via live TV over Tuner. not to use still picture
          I suspect you will find that the thin lines are causing something to overheat which means the T-con will shut down.
          I guess you could see what is overheating (a thermal camera helps, but if not, you may be able to use freezer spray carefully applied), and as a temporary fix, may be able to heat-sink it sufficiently such that it stays cool and continues operating. A likely guess will be a DC-DC converter on the T-con board. It is unlikely to be on the power supply.
          However I would never consider this a long term fix because if this fault is causing something to overheat, it is very likely that the driver chip that has the short present will also fail in short order, leading to a large black bar, more coloured lines or total panel failure.
          • Diah
            • Feb 2013
            • 6411
            well i agree with tom about heating. any overload will cause it. but we need to think there are SOS signal come out from panel self. if we hide it then later we can deal with heat issue. since we don't know which OLED screen serial on this set cant say where are the SOS signal pins but its almost the last 3 pins of the last ribbon. left side or right side, easy to try hide them one side by other with thin tape from T_CON driver side and check what will going on.. this will never harm the set at all.
            • j3scott
              • Jul 2021
              I have an XBR65A8G with the dreaded 4 blinking red lights. No picture. I can bypass the 4 blinking red lights and get the OS and audio to work by taping pin 19 of 51 from the main board to the t-con (near 'Error Detection' label) or taping the far right pin from the panel to the t-con board. I was also able to update the firmware by using a second panel for navigation. Still no picture. At times when the panel powers on, there will be horizontal red, blue or white lines across the screen or parts of the screen, but they're only there for a few quick seconds.
              I've also replaced the t-con board with no success. I can trigger a t-con error, 5 red blinks, by removing the flex cables from the main board to the t-con board. I assume if there is a real t-con error, I the circuit would trigger 5 red blinks before triggering 4 red blinks. Given that the real error is 4 red blinks, I think there's a short in the panel board.
              Have you ever taken apart the panel to see if there are any circuits to repair? There are a few accessible capacitors on the panel next to the flex cables but I see no way to explore further without destroying the panel or cutting into it with a rotary tool.
              • Audeze
                Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                by Audeze
                I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                Does...
                10-06-2024, 08:54 PM
              • bialag
                Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
                by bialag
                I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
                Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
                03-25-2025, 05:56 PM
              • Watson306
                6 Red Blinking lights (left side darker) on Sony KD-49XE8396
                by Watson306
                I've got a Sony KD-49XE8396 TV that will switch on show the Sony logo then the Android logo and then switches off, and then blinks red 6 times.
                I've read that this is the backlight, and during it showing the initial logos I can see that the left side is definitely darker.
                I've also read that you can bypass the error to get it working but I'd prefer to fix it if at all possible. Any help would be appreciated.
                Many Thanks in advance.
                11-01-2022, 05:33 AM
              • YasaCh
                Sony kdl 40p5500 red light keeps blinking 3 times
                by YasaCh
                Hello...
                my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                i opened the back cover no sign of damage on the powery suply or motherboard
                when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                07-07-2025, 11:53 AM
              • shahnld
                Sony kdl 65xg9505 green amber blinking
                by shahnld
                Good Day.
                I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                01-03-2024, 03:05 PM
