Sony kdl-40hx750 bios dump
  • medinfo
    • May 2016
    • 328
    • Morocco
    Sony kdl-40hx750 bios dump plz
    Logic Board : WQL-C4LV0.1 Samsung
    • 12146
    • U.S.
    Re: Sony kdl-40hx750 bios dump
    https://www.sony-asia.com/electronic...loads/Y0015137
    • medinfo
      • May 2016
      • 328
      • Morocco
      i need bios dump not firmware utility, but i fixed it tank you
        • 12146
        • U.S.
        Never heard it called bios, heard it called firmware, It's a tv no?
        • Deno
          • Jun 2020
          • Ukraine
          Dump
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • DynaxSC
            by DynaxSC
            11-17-2023, 10:56 AM
          • jeewantha
            Samsung NT-R580 Bios Dump Required
            by jeewantha
            Hi Guys,
            I need a bios dump for the following laptop.
            Samsung NP-R580
            Motherboard : BREMEN-M REV:1.0 (091112)-5
            Serial Number : BA68-05578A 20
            Thank you​...
            05-20-2025, 05:03 AM
          • grimacelord
            Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
            by grimacelord
            This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
            Motherboard model number: DA0PAMB46A1 REV: A
            Secondary motherboard model number: 0PAB
            SKU: 685K4UA
            Serial number is: 5CD3223BJP
            Recently reflashed this laptop with latest BIOS and once...
            05-07-2024, 08:06 AM
          • DynaxSC
            Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
            by DynaxSC
            I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
            It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
            I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
            11-06-2022, 05:22 PM
