hisense tv
  • Dilane
    • Sep 2015
    • 38
    • Srilanka
    hisense tv
    Hello.
    I have this tv model ledn40k20dp that only show the logo ,when turn on and nothing more.
    i think that can be fault of eeprom but i dont know much about that problem.
    Any idea or help?
    Thanks and apologize for my bad english.
    Regards
  • Robinsosa
    • Nov 2013
    • 19
    • kenya
    Re: hisense tv
    EEPROM corrupted.
    You need to reprogrammed it with new bin file
    • diif
      • Feb 2014
      • 6978
      • England
      Re: hisense tv
      Try this.
      • Dilane
        • Sep 2015
        • 38
        • Srilanka
        Re: hisense tv
        thank you very much for your support
        • Dilane
          • Sep 2015
          • 38
          • Srilanka
          Re: hisense tv
          Originally posted by diif
          Try this.
          • SidneyCanadas
            93C46 and 93C56 EEPROM
            by SidneyCanadas
            I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
            https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
            Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
            06-14-2023, 01:16 PM
          • NYKing
            Hisense TV 32D33 - Replaced EEPROM, now menus have no text
            by NYKing
            The TV initially had a steady (not flashing) red standby light but did not turn on when power button was pressed. I tried all the usual “fixes” but nothing worked. TV would not turn on. After researching the issue, I concluded the cause was a bad EEPROM chip. I ordered the appropriate chip from ShopJimmy:
            https://www.shopjimmy.com/hisense-32...hoCOcUQAvD_BwE
            I took off the old chip using my hot air station and soldered on the new chip. I tested...
            10-07-2021, 05:06 PM
          • USmechS
            Hisense 65H6570F Logo shows then turns off
            by USmechS
            Hello everybody,
            I had this Hisense TV since November 2019 (Bestbuy Blackfriday special). Couple of nights ago my dad turned it off normally. In the morning it does turn on, shows the Hisense logo, then the LED light flashes and it turns off. It remains in the same state.
            Things I have done:
            A. Plug it off and on.
            B. Plug it off, pushing the power button for up to 2 minutes, plug it in.
            C. Contacted the customer service, They sent me a firmware update, with the file name:
            upgrade_loader_no_tvcertificate.pkg
            The zip file has this...
            04-25-2022, 03:06 PM
          • Verlengsnoer
            Bios splash/logo change
            by Verlengsnoer
            at firs, i hope this is the right place to post my question.
            Im looking for a tool to change the bios logo.
            everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
            i know that HP has a build in option to change the splash logo.
            but i want to change the manufacturer logo to an own logo.
            I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
            10-28-2022, 09:52 AM
          • A1rebirth
            Hisense H55A6500UK logo loading then black screen
            by A1rebirth
            I have an issue with my tv and was wondering if anyone has had a similar issue and could advise me.
            As stated its a hisense H55A6500, when you power on the logo loads, dissapears then black screen stays, it seems to flicker and a small line appears moving around the screen as it flickers sometimes 1cm long sometimes a few inches and sometimes none.
            I have to pull the plug to turn it off as buttons are unresponsive.
            Feels like a corrupt firmware maybe to me. I have contacted hisense but no replys as of yet two days later. Only file for...
            03-12-2021, 10:55 AM
