LG 55LB5800 Doesn't Boot
  • neilc6
    • Nov 2015
    • 1550
    Bought this TV expecting bad LED backlights but it appears to have firmware issues. When turned on the logo displays for about 10 seconds with the backlight on with the front LED flashing before turning off again. Guessing corrupt firmware or bad eeprom. Have a LG service remote and tried pressing INSTOP which should do a factory reset but doesn't seem to accept remote inputs when attempting to turn on. No firmware can be found online either. Also tried holding down the power button during turn on.
    Any suggestions before I buy a new main board? Can try looking for the flash IC and freezing it but haven't pulled the back cover off yet to confirm the main board part number. Found some sites with the main board for around $130 and one ebay seller that wants $250.
    Was curious with what LG oneprice charges for repair and it was $390 which is more than the value of the TV.
  • jjanssen7
    • Nov 2012
    • 252
    Re: LG 55LB5800 Doesn't Boot
    try 55lB6100 main board (cheaper) I've had good luck swapping between different 55LBXX mains with different tcons and LCD panels. I may even have a main board you could try if you are interested.
    • neilc6
      • Nov 2015
      • 1550
      55LB5800 appears to be a Canadian model so very limited supply. Ebay shows lots of LB6100 main boards and reasonably priced. Thanks for the tip. Just ordered one on ebay.
      • jjanssen7
        • Nov 2012
        • 252
        I should have added this: just check to make sure the wifi and button connectors on the 6100 model are the same as the one on yours(some have flat style, some have older double stacked style). Let me know if that ends up being an issue, I have lots of both types and they are interchangeable for the most part too.
        • neilc6
          • Nov 2015
          • 1550
          My 55LB6100 main board (paid $45 USD) came in and tv is working fine. Looks like the latest firmware sets the default picture mode to Auto Power Save (75% backlight) though Standard mode is still at 100% backlight. Also apps default to Standard mode and 100% backlight and you can only access the modified settings menu with the Q.Menu remote button.
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
          • ygorsan
            by ygorsan
            🧩 Problem Summary:
            • I
            07-28-2025, 08:34 AM
          • jb_Bak
            by jb_Bak
            CN6401
            Pin 01 NC
            Pin 02 NC
            Pin 03 "BL_ON": 0V
            Pin 04 "N/C"
            Pin 05 "STBY 3.3V": 3.5V
            Pin 06 "GND": N/C
            Pin 07 "AC_OFF"...
            09-27-2021, 04:52 PM
          • JDC
            (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
            by JDC
            ONN 100012588
            Issue: No Power, Then Rebooting After Main Board Change
            Short answer: replace main board and power board
            Technical answer: replace main board and Q306 & Q307 on power board.
            Long answer:
            TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
            07-15-2022, 07:39 AM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
