SONY XBR65x900E no image
  • charlie555
    • Feb 2018
    • 76
    • usa
    I received this TV yesterday First time turning it on I saw this Sony start up screen then it disappeared for flashing lights read four times. Ran a rest to green light turned back on had a Sony startup screen the beige screen but the Sony word was jettering up and down then it turned off. Now just back lights on and sound.
  • Diah
    • Feb 2013
    • 6437
    Re: SONY XBR65x900E no image
    1- you have double post for the info
    2- since this is android system first things you need to to do hard reset, how to
    plug it out from wall socket first, press on the TV side panel power and volum- minus keep them pressed then plug it in wall socket, the LED indicator will change from white to Green , release the 2 button .. give it time around 30 minute as it will restart 2 time and make new install , in case still no image you should hear the first install music sound stable after this 30 minute or less waiting time.. report your result
    • charlie555
      • Feb 2018
      • 76
      • usa
      Ok thanks just did will let you know
      • charlie555
        • Feb 2018
        • 76
        • usa
        Am I supposed to hear music first 3 min? Unplug tv from outlet held start and volume down same time green light came on and in 3 min started hearing music. Indicator light is white with music
        • charlie555
          • Feb 2018
          • 76
          • usa
          These are pic from the tcon board is this normal?
          • Diah
            • Feb 2013
            • 6437
            this look not good, before you spend on this set by replacing T-CON inspect the panel bonds they may also toasted .
            about hard reset. it mean this set was rested before and its on first install menu music,
            • charlie555
              • Feb 2018
              • 76
              • usa
              Thank you will Order and check before installing tcon board.
              • charlie555
                • Feb 2018
                • 76
                • usa
                Replaced tcon , no change
                • NSkyLab
                  Sony XBR-65X900F black and white image on one side (fading saturation)
                  by NSkyLab
                  I though I've seen all possible kinds of failures but this one is new...
                  Colors saturation is gradual.y fading out on the left side of the screen (all colors are fading out). While B&W image is looking good.
                  I tried replacing TCon but nothing changed. So this is looking like the panel failure. Is there a chance it can be fixed?
                  Any useful measured can be done on the panel's narrow pcbs? Is there may be something similar to taping trick to fix this issue?...
                  Yesterday, 07:37 PM
                • domix
                  Sony KD - 65XF9005 - No image, sound OK
                  by domix
                  at tv KD - 65XF9005 i have a problem.
                  Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
                  is this a common problem for this tv?
                  i attached pictures of inside. Supply board looks okey, no blowed caps....
                  07-21-2025, 06:37 AM
                  HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                  This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                  09-12-2024, 02:20 PM
                • Dreamcazman
                  Sony KV-XJ29M31 CRT TV - Very dim image on turn on
                  by Dreamcazman
                  Hi all, I recently picked up a Sony KV-XJ29M31 CRT TV (BG3R chassis, Australian model) cheaply & completed the RGB mux mod on it for some retro gaming. That worked great, however, I have another problem which I hope someone can help me with or at least steer me in the right direction.
                  Basically, the issue is when it's cold, it takes a while (like 2 mins) for the picture to come up. I think the image is there, it's just very dark or dim. I can hear the degaussing sound & I can change inputs & hear audio but no image.
                  Once it's running properly, it keeps...
                  02-28-2022, 07:47 PM
                • x_orange90_x
                  Sony KD-60X690E 6 Blinks, no image
                  by x_orange90_x
                  I just got this today and it has the infamous 6 blink code. I've read it's quite possibly bad backlights, and I intend to check them soon. However, I was just curious if the Sony logo should it's shouldn't be appearing briefly between powering on and the light starts flashing. I've read at least one other person had the logo flash quickly, but mine does not show anything at all, not even a flicker. The green light comes on and after about 5 seconds the red light flashes. So I'd expect in this 5 seconds to see the logo. This leads me to believe it could be a power supply issue.
                  I...
                  12-10-2024, 09:10 PM
