Sony XBR-55X900C on for a few seconds then off.
  • itelite
    • Aug 2016
    • 124
    1-894-595-12 - main board
    XBR-55X900C - model
    Working on this Sony. Starts to turn on, animated logo runs for maybe 2-4 seconds, freezes, tv turns off. Sometimes relay clicks off then back on. Cycles indefinitely.
    Nothing on board getting abnormally hot.
    5v on USB will turn off with cycle as expected.
    power on signal between PSU and main board will drop from 3.55 to 3.49 (odd drop in my opinion). Not sure if significant. I would think 3v or 0V. Holding it at 3.55 with external supply changes nothing.
    Anyone know what actually controls the main board into the on/running state? There is a PIC16 on the board, but i cant find anything in the way of documentation as to what it is doing. It has 2 transistors connected to it. I moved both out of circuit with no change in condition.
    I know others with this exact condition have replaced the main board and that worked, but if anyone has any ideas as to what may be the cause, i would much rather repair and document the failure vs just putting a board in it.
  • brucetv
    • May 2015
    • 281
    • united states
    Re: Sony XBR-55X900C on for a few seconds then off.
    I had this model in several times and after every attempt to do a component level repair on these main boards I have failed including the 65" main board version. XBR stands for Xtra Brain Rack because the Main boards are overkill and usually have decent chipsets making them harder to diagnose. By the time I got numbers off components, checked their specs, run traces, and start probing I slowly lose hope. If it's your personal Tv and you have plenty of time on your hands go for it and please let us know what you found. If we have a customer waiting then a fresh main board with a new firmware installed when we get then new main then it usually ends the boot looping power cycling, installs the new firmware and turns off then on and instructs you to take out the usb when firmware install is finished. Very nice picture too.
    • itelite
      • Aug 2016
      • 124
      Got a new board. now the tv powers on. Nothing on screen at first, plays some weird music for a while. does nothing then goes to sleep (?)
      Put newest firmware on a usb drive and put it in. blinked green and amber for a while. changed to slowly pulling white and oddly started cycling through colors on the screen. left it alone for 20 minutes at least. went to sleep again.
      hit power button, back to color cycle.
      Never an indication on screen of a firmware update happening.
      I dont do a ton of sonys, is a human sacrifice required?
      • itelite
        • Aug 2016
        • 124
        Nevermind. Got it.
        If at first you dont succeed, do the exact same thing again, and for some reason it will work the second time.
        • jb_Bak
          by jb_Bak
          CN6401
          Pin 01 NC
          Pin 02 NC
          Pin 03 "BL_ON": 0V
          Pin 04 "N/C"
          Pin 05 "STBY 3.3V": 3.5V
          Pin 06 "GND": N/C
          Pin 07 "AC_OFF"...
          09-27-2021, 04:52 PM
        • Dani_2024
          by Dani_2024
          10-28-2024, 05:06 PM
        • JDC
          (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
          by JDC
          ONN 100012588
          Issue: No Power, Then Rebooting After Main Board Change
          Short answer: replace main board and power board
          Technical answer: replace main board and Q306 & Q307 on power board.
          Long answer:
          TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
          07-15-2022, 07:39 AM
        • cheeky2
          by cheeky2
          05-25-2024, 03:27 AM
        • cheeky2
          Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
          by cheeky2
          For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
          See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
          01-08-2024, 05:56 AM
