Samsung plasma PN64F8500 Y-sustain board
  • aG738
    • Apr 2019
    Guys, I need your advise to troubleshoot the Ysus board on Samsung PN64F8500. The symptoms are as follows:
    When switching the TV on via remote, no video, blinking LED for about 1 min. Then sound is on, all remote controls are fully functional, but still no video. If I am lucky, it works from the 2nd switch on depending on the room temperature.
    First, I was thinking that it was the power board, bad capacitors. I have checked all electrolytic capacitors, measured ESR (I use Atlas ESR70), but could not find any faulty ones.
    One more thing. It looks as the ambient temperature affects it a lot. It works perfectly fine when it is below 22 °C, switches on from the 2nd try under 22 °C – 24 °C, and almost impossible to switch over 25 °C.
    According to many threads, having sound and no video means problems with the Ysus board. So, I have checked all electrolytic capacitors on the Ysus board and again could not find any bad ones. Still I replaced most of electrolytic caps, but it didn't help. Then I found this thread on avsforum - people had a very similar problem with the PN64F8500, which was fixed by replacing 106 MLCC caps on the Ysus board. I removed the suspected 106 caps, a few of them measure only 8uf, which is just below the tolerance level.
    I can only measure capacitance over 1uf with the Atlas and am not sure if I want to buy a decent LCR meter to measure all MLCC.
    What shall I do next? I am thinking to replace all 106 caps, but maybe it makes sense to replace all ceramic caps on the Ysus board because the TV is 6 years old?
    Since the TV is very sensitive to the ambient temperature and can be switched on only below 22 °C, should it be only because of a faulty ceramic cap?
    Any suggestions? Just replace all caps blindly or narrow bad ceramic caps down somehow without LCR?
    Thanks!
  • jjanssen7
    • Nov 2012
    • 252
    Re: Samsung plasma PN64F8500 Y-sustain board
    https://www.badcaps.net/forum/showth...ight=PN64F8500
    • aG738
      • Apr 2019
      Thanks! I have replaced all 106 (10uf) capacitors on the Y-sus and everything works perfectly fine. Still I cannot figure out what was wrong with the old caps as they all measure within the 20% tolerance band. Probably, I need to test them under different frequencies and different voltages to find out what exactly the problem was.
      • jjanssen7
        • Nov 2012
        • 252
        In my experience 20% makes a difference with this YSUS. That's your answer right there. Given your testing might add 5% difference, your caps could be 25% off their specs.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
        • Cooperr
          Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
          by Cooperr
          I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
          The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
          10-21-2025, 01:11 PM
        • stecos
          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
          by stecos
          Hi everyone!
          I happened several times, in the search for help from the web, to consult this very interesting forum.
          So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
          Having said that I come to the gist of my post on the forum as the title suggests.
          For my passion for technology I'm now collecting several...
          11-28-2022, 11:39 AM
