Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
  • diif
    • Feb 2014
    • 6978
    • England
    #61
    Re: Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
    Originally posted by Davi.p
    Which stencil?? I have no stencil obviously.. I will not use it..
    My reflow worsen the situation so i go for reballing and if does not work maybe a new chip ordered..
    My mistake, they cost £10/$10/€10 and it saves having to manually place 788 balls. Why would you not buy one ?
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4462
      • Italy - Milan
      #62
      I cannot wait for the stencil to arrive to know which is the balls size to order and wait another month or two to begin the job.. i think i will spend half an hour or less to place the balls by hand so maybe i can do it so..
      • diif
        • Feb 2014
        • 6978
        • England
        #63
        https://www.ebay.co.uk/itm/9x9-FNP10...-/273592452088
        0.6mm balls.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4462
          • Italy - Milan
          #64
          Ok thanks!
          • Maalobs
            • Jun 2016
            • 120
            • Sweden
            #65
            While I was at it, I also took a backup of the EDID config in the TV.
            The EDID is stored in this chip:
            Apparently it's a huge hassle to get access to the datasheet for it from Lattice, who nowadays owns Silicon Image.
            But it's not needed, there is just one detail there that is important to know; this particular chip does not support writing to EDID via HDMI, it must be done through the I2C-bus.
            Once you know that, you can handle writing any corrupt bytes in the register with a BusPirate or a Raspberry Pi.
            Reading the EDID works through HDMI of course, here is how it's done from a computer with Linux that has the HDMI-output connected to one of the inputs on the TV:
            Code:
            knoppix@Microknoppix:~$ su -
            root@Microknoppix:~# modprobe i2c-dev
            root@Microknoppix:~# apt-get update
            root@Microknoppix:~# apt-get install i2c-tools
            # List the available I2C-buses on your computer:
            root@Microknoppix:~# i2cdetect -l | sort
            i2c-0 smbus   SMBus I801 adapter at 3040   SMBus adapter
            i2c-1 i2c     i915 gmbus ssc         I2C adapter
            i2c-2 i2c     i915 gmbus vga         I2C adapter
            i2c-3 i2c     i915 gmbus panel         I2C adapter
            i2c-4 i2c     i915 gmbus dpc         I2C adapter
            i2c-5 i2c     i915 gmbus dpb         I2C adapter
            i2c-6 i2c     i915 gmbus dpd         I2C adapter
            i2c-7 i2c     DPDDC-A             I2C adapter
            # List all available device addresses on each I2C-bus, then look for any device address 0x50 in the output:
            root@Microknoppix:~# perl -we 'system("i2cdetect -y $_") for 0..7'
               0 1 2 3 4 5 6 7 8 9 a b c d e f
            00:     -- -- -- -- -- 08 -- -- -- -- -- -- --
            10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
            20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
            30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
            40: -- -- -- -- 44 -- -- -- -- -- -- -- -- -- -- --
            50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
            60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
            70: -- -- -- -- -- -- -- --
            00:     -- -- -- -- -- -- -- -- -- -- -- -- --
            40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
            30: -- -- -- -- -- -- -- -- -- -- 3a -- -- -- -- --
            40: 40 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
            50: 50 -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- <- 0x50 here
            00:     03 04 05 06 07 08 09 0a 0b 0c 0d 0e 0f
            10: 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f
            20: 20 21 22 23 24 25 26 27 28 29 2a 2b 2c 2d 2e 2f
            30: -- -- -- -- -- -- -- -- 38 39 3a 3b 3c 3d 3e 3f
            40: 40 41 42 43 44 45 46 47 48 49 4a 4b 4c 4d 4e 4f
            # Only one instance of address 0x50 on this computer, on the 5th I2C-bus, so dump the values of that device on that bus:
            root@Microknoppix:~# i2cdump -y 5 0x50
               0 1 2 3 4 5 6 7 8 9 a b c d e f  0123456789abcdef
            00: 00 ff ff ff ff ff ff 00 41 0c 00 00 01 01 01 01  ........A?..????
            10: 2a 16 01 03 80 84 4a 78 0a e6 92 a3 54 4a 99 26  *?????Jx????TJ?&
            20: 0f 4a 4c 21 08 00 b3 00 95 00 a9 40 90 40 81 00  ?JL!?.?.?.?@?@?.
            30: 81 80 81 40 01 01 02 3a 80 18 71 38 2d 40 58 2c  ???@???:??q8-@X,
            40: 45 00 00 d0 52 00 00 1e 02 3a 80 d0 72 38 2d 40  E..?R..??:??r8-@
            50: 10 2c 45 80 00 d0 52 00 00 1e 00 00 00 fc 00 50  ?,E?.?R..?...?.P
            60: 68 69 6c 69 70 73 20 46 54 56 0a 20 00 00 00 fd  hilips FTV? ...?
            70: 00 30 3e 0f 46 11 00 0a 20 20 20 20 20 20 01 93  .0>?F?.?   ??
            80: 02 03 3a f1 52 10 1f 20 22 21 05 14 04 13 12 03  ??:?R?? "!??????
            90: 11 02 16 07 15 06 01 26 09 1f 07 15 07 50 83 01  ???????&?????P??
            a0: 00 00 70 03 0c 00 10 00 38 2d af 4c 4c d0 04 01  ..p??.?.8-?LL???
            b0: 40 01 ff e3 05 03 01 e2 00 49 01 1d 80 3e 73 38  @?.?????.I???>s8
            c0: 2d 40 7e 2c 45 80 00 d0 52 00 00 1e 01 1d 80 d0  -@~,E?.?R..?????
            d0: 72 1c 16 20 10 2c 25 80 00 d0 52 00 00 9e 01 1d  r?? ?,%?.?R..???
            e0: 00 bc 52 d0 1e 20 b8 28 55 40 00 d0 52 00 00 1e  .?R?? ?(U@.?R..?
            f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4a  ...............J
            # Save the results:
            root@Microknoppix:~# i2cdump -y 5 0x50 > dump.txt
            root@Microknoppix:~# mv dump.txt /home/knoppix/
            root@Microknoppix:~# chown knoppix:knoppix /home/knoppix/dump.txt
            root@Microknoppix:~# logout
            knoppix@Microknoppix:~$ logout
            Here are some references about reading the EDID:
            https://www.youtube.com/watch?v=IGg1nyTY6oc
            https://www.youtube.com/watch?v=8IMkGdeXcS4
            https://en.wikipedia.org/wiki/Extend...ification_Data
            • Maalobs
              • Jun 2016
              • 120
              • Sweden
              #66
              I'm finished with everything on the TV now, hopefully it will have many more good years left in it.
              The new heatsink is in place:
              I also put a small heatsink on the NAND-chip, but it's on the underside of the board so it's not visible here.
              The chassis got a classic redneck solution:
              Say hello to my little friend:
              Thanks for all your help guys!
              I have squirreled away all the firmware images from this model, so let me know if you need a copy of anything.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4462
                • Italy - Milan
                #67
                From Windows you can use MonInfo software from Entech to read/write EDID..
                • Maalobs
                  • Jun 2016
                  • 120
                  • Sweden
                  #68
                  Sure, if you want to pay money for something that's free.
                  I don't normally use Linux but it's something I have needed to learn to be able to get things done.
                  In this case, I booted my laptop from a USB-stick with Knoppix, one of many different bootable live systems with Linux.
                  It's quite handy to have ready for occasions like this.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4462
                    • Italy - Milan
                    #69
                    The SW i've said is free...
                    • Maalobs
                      • Jun 2016
                      • 120
                      • Sweden
                      #70
                      It's shareware so technically you should pay for it, but I'll agree to calling it "free".
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4462
                        • Italy - Milan
                        #71
                        Yes, in fact It's a strange program, i can modify data and set write mode but i've realized the writing is not functional..
                        • Maalobs
                          • Jun 2016
                          • 120
                          • Sweden
                          #72
                          I forgot to mention; I have posted the contents of the SPI Flash and I2C EEPROM in this sticky thread, in case anyone has use for them:
                          https://www.badcaps.net/forum/showpo...&postcount=533
                          • HermannS
                            • Dec 2014
                            Hello folks, Herr Alpengeist speaking :-)
                            I found this thread while going through the visitor stats of my blog. Thanks for stopping by!
                            I gave up on the QFU boards. It is pure luck whether the CPU will wake up or not. I had reflowed and reballed the heck out of these things and never got any repeatable results. The QFU1.1 boards are so thin that they warp terribly. The QFU1.2 are a bit better in that respect. I am pretty sure that the CPU is to blame and not some balls. The infamous "K" error appears in both QFU1.1 and 1.2 models. Their board layout is different. It would be a big coincidence if the same balls broke. No, I think the CPU is to blame.
                            Only the case when the device is totally dead with a scrambled boot SPI has a 100% repair success rate. Alas, I only had that once. All others were CPU-related.
                            There are P120 CPUs (QFU1.1 and QFU1.2 6008 models) on eBay from Poland. They look legit. Unfortunately, the P240 CPU for the higher QFU1.2 models (7008, 8008) are not available.
                            I suggest that one reheat attempt (without full reflow because that's not the issue) at about 225°C can be done and if that doesn't fix it: dump it. Sad but true. A terrible TV series that was.
                            • Maalobs
                              • Jun 2016
                              • 120
                              • Sweden
                              #74
                              Hi, and thanks for your very detailed and well thought-out blog posts about repairs, I found them both educational and inspiring.
                              • amennone
                                • Feb 2015
                                • 63
                                • italy
                                #75
                                Salve , ho lo stesso problema codice errore 53 con Philips 55PFL8007K12
                                Telaio / Versione : QFU1.1E LA
                                Power Supply : FSP197-4FS01 2722 171 90676 REV : 01
                                Pannello : LTA550HQ19
                                Main board : 3104 308 98314
                                Il televisore si presenta completamente spento .
                                Le tensioni che leggo sono la 3v3s = 3v3 e la STB= 3v1
                                Ho riprogrammato la spiflash 7CT3 (M25P10) ,
                                sul pin 2 del connettore 1M95 la alimentazione
                                è passata a livello logico basso , da 3v1 a 0 volts .
                                La 12 volts , ora , è presente ,
                                come le altre alimentazioni sulla main -board .
                                Ma ottengo codice errore 53 .
                                Ho provato a collegarmi con Hyperterminal al jack di servizio ,
                                ottengo queste informazioni (vedi allegato )
                                Allego anche lettura della Spi 7CT3 prima della programmazione .
                                Il bin, che ho riprogrammato per la SPI è per un processore Fusion 77
                                Mentre il processore sulla main è un Fusion P240 FNP202-B1E32 .
                                Può essere questo il problema ?
                                Una altra domanda , perche con Hyperterminal ottengo questo log ?
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4462
                                  • Italy - Milan
                                  #76
                                  Amennone di plcforum giusto? Qui devi scrivere in inglese! Controlla su plc una disc. recente di Ottaviucci, il problema e' il processore..
                                  • amennone
                                    • Feb 2015
                                    • 63
                                    • italy
                                    #77
                                    Hi, I have the same problem with error code 53 with Philips 55PFL8007K12
                                    Chassis / Version: QFU1.1E LA
                                    Power supply: FSP197-4FS01 2722 171 90676 REV: 01
                                    Panel: LTA550HQ19 Card
                                    mother: 3104 308 98314
                                    The TV is completely turned off.
                                    The voltages I read are 3v3s = 3v3 and STB = 3v1
                                    I reprogrammed the spiflash 7CT3 (M25P10),
                                    on pin 2 of connector 1M95 the power supply
                                    it has gone to a low logic level, from 3v1 to 0 volts.
                                    The 12 volt, now, is present,
                                    like the other feeds on the mainboard.
                                    But I get error code 53.
                                    I tried connecting to Hyperterminal at the service jack,
                                    I get this information (see attachment)
                                    I also enclose the Spi 7CT3 reading before programming.
                                    The trash, which I reprogrammed for SPI is for a processor,
                                    is a Fusion P240 FNP202-B1E32.
                                    Can this be the problem?
                                    Another question, why do I get this log with Hyperterminal?
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4462
                                      • Italy - Milan
                                      #78
                                      And open up your own discussion,,this is already too fitted
                                      • maki
                                        • May 2011
                                        • 6
                                        #79
                                        Hello
                                        I was wondering if someone encountered a blank SPI ?
                                        I have a 46pfl8008, it has 2 blinks on level1 and 53 on level 2.
                                        Recovery isn’t working.
                                        I’ve suspected the SPI (25p10) and because it’s the easiest chip to check.
                                        I’ve used this programmer
                                        https://www.ebay.com/itm/CH341A-Seri...53.m1438.l2649
                                        with a clip
                                        https://www.ebay.com/itm/Soic8-Sop8-...53.m2749.l2649
                                        To my surprise, the chip was totally blank – all FFs.
                                        Any ideas?
                                        • hulko
                                          • Jan 2020
                                          • Italia
                                          #80
                                          Hello, sorry i'm new
                                          somebody can explein how i can activate the service modo on 60PFL8708S
                                          because i'd like to try to re-install the original software before the boot of TV
                                          • ngml
                                            Repair of an LG split AC system indoor unit PCB
                                            by ngml
                                            I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                                            This indicates an error in the communication between the outdoor and the indoor unit.
                                            The outdoor unit is fine, so the problem is the indoor PCB.
                                            The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                                            I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                                            Does anybody have the schematics of this board,...
                                            02-01-2025, 12:55 PM
                                          • CoinCoin88
                                            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                            by CoinCoin88
                                            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                            09-15-2025, 03:36 AM
                                          • DrDos
                                            Unit runs but no speaker output kenwood KR-6030
                                            by DrDos
                                            I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
                                            09-14-2025, 09:57 PM
                                          • nobbnobb1
                                            Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
                                            by nobbnobb1
                                            Hi guys,
                                            Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
                                            When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
                                            02-03-2022, 11:14 AM
                                          • BC_TechForum_drb
                                            Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
                                            by BC_TechForum_drb
                                            Sub: Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
                                            Ref: 1/ MacPro6,1 Late 2013/A1481 MD878LL/A (3.5 GHz 6 Core Xeon E5-1650v2)
                                            Gfx-B: APN: 661-7548 PPN: 820-3533-A AMD FirePro D500-B 3GB Vmem
                                            2/ Figure 1 Gfx-D500-B Front Facing
                                            3/ Figure 2 +5v supply (zoom-in)
                                            Intro:
                                            While troubleshooting a Mac Pro(6,1) referenced above I discovered the +5v secondary supply did not stand up on the D500-B graphics card as a result of a missing enable signal. The +3.3v secondary rail was the only rail that did standup. I tried to perform...
                                            12-07-2023, 09:55 PM
