CRT TV:What causes this kind of geometry issue?
  • GraphicMan
    • Aug 2018
    • 124
    • Egypt
    Hello
    anybody knows what is responsible of producing this kind of geometry issue? in an LG 29" flatron crt tv?
    thanks
  • R_J
    • 9624
    Re: CRT TV:What causes this kind of geometry issue?
    could be a bad one of these, scope the vertical circuit
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8711
      Well with flat CRT screens a lot of magic is needed to make sure that things are lined up. A lot of the times a microcontroller has a setting to control parallelogram alignment and a slight misadjustment may look like that...
      But yes a bad one of those things ^^ could cause it too...
      • GraphicMan
        • Aug 2018
        • 124
        • Egypt
        wow a bad cap may cause that?
        i am almost sure that this is a new thing to the tv, i did not notice it before
        i want to add also that that tv has a lot of enlarged areas when it is bright
        meaning if there is a wide bright strip in the screen like a white wide cnn news bar, that area is kind expand wide and cause deformation, is that fixable or it depend on the tv model?!!
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8711
          There are a lot of strange controls needed to control a flat screen short neck CRT versus a traditional long neck curved screen.
          /_/ and \_\ parallelogram control
          /_\ and \_/ trapezoid control
          (_) and )_( barrel and pincushion control
          You'll have to supply a photo to describe.
          • R_J
            • 9624
            Why not post the model number so we know what we are dealing with. An actual picture of screen with the fault might help also.
            Check when there is a large white area is there bleading of a color(R,G,B,) to the right of the white area? If there is it could be the crt is weak.
            Does lowering the contrast or brightness help ?
            You may also have a power supply problem, When there are large white areas on the screen, that demands more current from the power supply, If this happens the voltage can drop or the pwm circuit gets noisy causing lines etc. on the screen.
            Is this a HD tv, check it with a different resolution and different input.
            • GraphicMan
              • Aug 2018
              • 124
              • Egypt
              no it is not an HD tv
              it is RT-29FB75VE
              no there is no bleeding when the white areas expand wide
              i dont think the crt is weak because the colors, contrast and sharpness is really good (better than most new led tv's)
              lowering contrast or brightness have no effect on this phenomena
              my other sony 21" crt tv make it too but in a much smaller manner
              I have played ALOT in the service secret menu, and i was able to adjust the screen through the time to its best ever possible state
              however there are a LOT of other functioned in it that I dont understand what does it make and it seem not making any difference although its wide range of choice (0 to 2000!!!)
              let me share these menus
              please dont judge the vertical lines from these pics as it is not clear with so many details
              • rounin
                MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                by rounin
                🛠 Original Issue
                ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                04-19-2025, 01:18 AM
              • ugamazing
                by ugamazing
                12-17-2024, 07:05 PM
              • ahmarzo
                Acer laptop battery draining issue
                by ahmarzo
                Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                08-02-2025, 06:39 AM
              • elmark
                HP 15-cw1002ua strange keyboard issue
                by elmark
                HP Pavilion 15-CW1002UA
                S/N 5CD0251CBC
                P/N 7KE54EA
                Hello guys!
                I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                It powers on OK and has no other issues except the following:
                • CAPS LOCK does not work at all
                • Fn button toggles Flight Mode
                • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                • (with SHIFT pressed: 't%' and 'y^' respectively)
                I initially thought it was a keyboard malfunction (internal short, etc.),
                but when I press and hold...
                06-27-2025, 01:10 AM
              • Simone Vergani
                Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
                by Simone Vergani
                I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
                To assist with troubleshooting, I'm attaching two power circuit schematics:
                • Power
                03-05-2025, 02:25 PM
