Sanyo DP42740 - Powers On, No Video - Missing 15/25v
  • R_J
    • Jun 2012
    • 9624
    Re: Sanyo DP42740 - Powers On, No Video - Missing 15/25v
    If you have +72 volts (Vs) on pin #1 of P2 and NOT on Pin #1 of P11, You must have a broken trace as both points are connected together
    Also on P11, Pin #4 you should have 15 volts
    If Q407 C (tab) has 16 volts, check on the transistor next to it (Q30?), Its tab will 16 volts, then its emitter should have a similar voltage as its base, that emitter voltage should go up to the PFC ic's VCC pin
    That 72 volts is low and should be 191 volts, again this is likely due to the low supply voltage (160 instead of 400) But the fact there is any voltage means a lot of the circuit is working.
    Are you sure the voltage across the main filters (CE201/2) does'nt change from 160 volts to 400 volts when the tv is turned on?
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • mferna14
      Logic Board 820-01987-A missing PP3V3_S5
      by mferna14
      Hi good Friends., today working on a Macbook Pro A2289, Logic board 820-01978-A. The history was liquid spill, Cleaned & replaced all corroded components & now the logic board shows 20v & .01amp on the meter. Not taking in any amps. Upon trouble shooting I get the required stable voltages 5V, PP3V3_G3H 3.3V but no PP3V3_S5. Checked the schematic, assume that this is generated from U7800. Checked all the Input/Output voltages on this chip. All is fine, except PP3V3_S5 is missing. Resistance from GND to PP3V3_S5 is 146 Kohms. First I need to make sure whether PP3V3_S5 is generated from...
      06-07-2025, 05:07 PM
    • Hakuu
      by Hakuu
      Hi There,
      More Details
      TV Model - LG OLED77G1PUA
      07-12-2023, 02:37 PM
