K9GAG08U0E SAMSUNG nand flash file
  • chrislyons
    • Apr 2018
    • 39
    hello can somone point me in direction this file please done search with no luck .
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8340
    Re: K9GAG08U0E SAMSUNG nand flash file
    That K9GAG08U0E is the part number of the flash chip. No wonder you don't find anything. You need to post your model number of the TV. Something like UE32D5500 for example.
    • chrislyons
      • Apr 2018
      • 39
      sorry its samsung ue40d5520 its on restart loop, this nand ic may be faulty
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8340
        google maybe something like "ue40d5520 dump" that set has an EEPROM and a NAND. Your nand is faulty. Maybe there is some vendor that sells the Nand pre programmed. You may have to match with the main board number. It starts with BNxx-something. Maybe post a dump request into the EEPROM dump threat here: https://www.badcaps.net/forum/showthread.php?t=59877
        • chrislyons
          • Apr 2018
          • 39
          hello there are programed nand on ebay much rather solve problem my self i do have propper programing gear . gq-5x
          • finntricky
            • Jan 2014
            • 449
            • uk
            i have bought 4 from different sellers on ebay, and all still done the same once replaced,
            i dont think they are programed at all
            • Unspun01
              • Jun 2011
              • 349
              Does the auction state that the NAND is specifically programmed for your TV? Or are you buying empty ICs for which you need to program yourself?
              Please provide more information.
              Please provide the eBay auction links to the 4 you have purchased for us to review.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8340
                since you have a programmer, take the nand out, read it and save the dump. Erase the nand. Then do a blank check on the nand. See how many sectors are bad.
                • chrislyons
                  • Apr 2018
                  • 39
                  ok thank you , i will check that is there chance sofware might be on here
                  • chrislyons
                    • Apr 2018
                    • 39
                    this is message i got Copyright (C) 2014-2018
                    GQBlaster 1.10
                    Target: K9GAG08U0E
                    CE Pin = 1
                    -load
                    -read
                    Time 00:08:40 (.692)
                    Source bad block No. 203
                    Source bad block No. 485
                    Source bad block No. 1014
                    Source bad block No. 1025
                    Source bad block No. 1745
                    Source bad block No. 1893
                    Source bad block No. 2074
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8340
                      yeah... that nand is toast.
                      • chrislyons
                        • Apr 2018
                        • 39
                        cheers bud i did get to read this is it worth reloading same file back on to new nand ? i cant find software any where
                        • chrislyons
                          • Apr 2018
                          • 39
                          thats why i want to learn my self ,i not lining there pockets not to be trusted
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8340
                            that is what I would do. I'd order a new blank nand IC and in the meanwhile I'd look and ask for a nand dump for that TV. If by the time the new IC comes, no dump was found, I'd try copying the saved file from the old nand into the new nand, put that back onto the main board and see what's happening after you turn on the TV.
                            BTW. what happens if you read the nand after you freeze it with a can of air upside down?
                            • diif
                              • Feb 2014
                              • 6978
                              • England
                              Try this @chrislyons https://se******************************IJzD2ym-gfQ
                              • chrislyons
                                • Apr 2018
                                • 39
                                hi thanks it says link has expired.
                                • powerzx
                                  • Nov 2015
                                  • Poland
                                  https://www.elektroda.pl/rtvforum/do...php?id=1154715 UE46D5520RB NAND.zip
