Do I have this chip in correct, I don't see a dot on it.
chip orientation
Re: chip orientation
That ncp1608 is the pfc ic, it likely drives a mosfet that is shorted, What's the board used in? Is this a Sharp power supply board by chance?
If it is, and that R7900 is blown, IC7903 shorted.
As for transistors, they only go in one way, the correct way.Last edited by R_J; 03-13-2019, 09:49 AM.Comment
Replace ic and mosfet, plugged in and fried it again....ugh!Comment
Which ic are you talking about? What mosfet are you refering to?
the ic in post #1 has nothing to do with the ic pictured in post #5
What number are you replacing IC7903 with? IC 7903 is the standby controler ic. It has nothing to do with any mosfets,
The blown resistor in post #3 picture 3 is the fuse resistor for the standby ic IC7903
You have likely caused more problems by installing parts backwardsI replaced 3 transistors they all look correct. They can go in either way right?Last edited by R_J; 03-20-2019, 06:44 PM.Comment
Ic7903 was replaced and resistor that was blown. Transistors only can mount up one way. I replaced everything in this kit. https://www.shopjimmy.com/sharp-runt...repair-kit.htmComment
by DynaxSCHi
I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6... -
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... -
by TroystainHello, anyone here have updated ezp2023+ chip database in .dat file format.
I need to add w25q256jveq chip but I do not know what data should I type.
I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....11-25-2024, 12:53 AM -
by inck243Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
The BIOS...-
Channel: BIOS Requests ONLY!
by thxd43Hello, first of all, excuse me, I am using the translator, English is not my native language.
I have a Lenovo ideapad 330S - 14IKB laptop.
The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a... - Loading...
