Sony KDL-55EX620 stand-by present, no stand-by light, AC_OFF_DET @.47V
  • budwich
    • Jul 2015
    • 3097
    Re: Sony KDL-55EX620 stand-by present, no stand-by light, AC_OFF_DET @.47V
    I guess the question would be... forgetting plugging in the usb.... what happens when you power up the set and attempt to turn it on with the "new board"? I would suspect that if you don't get some "form" of display, then you have more problems than firmware.
    I guess with your experience in this post, you should be able to quickly check the voltage to see if anything has changed from the "old board" situation.
    • Diah
      • Feb 2013
      • 6565
      Sony EX series 5 Time red LED flash cause by shorted components on T-CON or the Panel Taps. use your DM on Diode peep ton mode black to chassis and with red line check all C which had short and follow it line.
      • DXseekerMO
        • Feb 2018
        • 1119
        • US
        #43
        Ok I checked the LVDS cable at the main board and it was misaligned. Re-installed it and plugged the TV in. Immediately the red standby light was on and the amber light was flashing. I inserted the thumb drive and it looked like the update was taking. Eventually the amber light turned off and the stand-by light was flashing 10 blinks.
        So....what is the good news? Did I brick the turd?
        They call me......."threadkiller"
        • Diah
          • Feb 2013
          • 6565
          forget the update... if this MB came to you will last firmware it will never take it again.. consider only on the error
          so confirm again that you have now 10 flash error ?
          • DXseekerMO
            • Feb 2018
            • 1119
            • US
            #45
            Yes, 10 flash error confirmed.
            Board came from a reliable supplier/refurbisher.
            • budwich
              • Jul 2015
              • 3097
              agree.... does that set actually startup and display?
              • DXseekerMO
                • Feb 2018
                • 1119
                • US
                #47
                Plug TV in, stand-by light on solid.
                Turn TV on, green light comes on, backlights flash but no picture (screen does not white flash anymore but no OSD).
                Stand-by light starts blinking 10 times and repeats
                • Diah
                  • Feb 2013
                  • 6565
                  plug ur tv out from wall socket for about 5 minutes. at this time press the power knob on the TV several time. after the 5 minute plug it on and tell the result..
                  • DXseekerMO
                    • Feb 2018
                    • 1119
                    • US
                    #49
                    Stand-by light illuminated solid red, no flashing
                    • Diah
                      • Feb 2013
                      • 6565
                      with yours RC inter diagnostics mode by press as following from STB state
                      Display, Channel, 5, Vol Minus, ( Not plus ) then Power
                      • DXseekerMO
                        • Feb 2018
                        • 1119
                        • US
                        #51
                        Don't see a button on the remote labeled "channel" other than the channel up/down button. Am I missing something?
                        • Diah
                          • Feb 2013
                          • 6565
                          channel 5 mean the no 5 on RC
                          • DXseekerMO
                            • Feb 2018
                            • 1119
                            • US
                            #53
                            lol ok so to confirm the buttons to press on the remote are:
                            display, 5, volume down then power?
                            • Diah
                              • Feb 2013
                              • 6565
                              correct
                              • DXseekerMO
                                • Feb 2018
                                • 1119
                                • US
                                #55
                                correct
                                After pressing the buttons in the order specified the TV turns on, the Sony logo comes on screen, the TV appears to turn off and we're back to the 10-blink code.
                                • Diah
                                  • Feb 2013
                                  • 6565
                                  at least this first time you see Sony logo on screen..or..?
                                  Try again to plug it out from wall socket for 5 minutes or more then repeat this.. diagnostics mode
                                  it may this error was registered on MB before it came to you... however we need now to clear all error code on it
                                  • DXseekerMO
                                    • Feb 2018
                                    • 1119
                                    • US
                                    #57
                                    The screen was facing down after re-setting the LVDS. Before entering diagnostics mode I put the TV back on the stand with the back off and this is when I saw the Sony logo.
                                    I am letting it sit for 5min then I will re-try
                                    • DXseekerMO
                                      • Feb 2018
                                      • 1119
                                      • US
                                      #58
                                      This time it looks like the Sony logo tried to display but it did not, back to the 10 blink code
                                      • Diah
                                        • Feb 2013
                                        • 6565
                                        do it again.. by plug it out from wall socket. this time reset all cable socket on the Set. check the LVDS side which was not correct seating. if any of silver pin was broken or moved to side or get short
                                        • Diah
                                          • Feb 2013
                                          • 6565
                                          after this time when you do it, don't inter diagnostic mode... inter from STB state to service menu... with RC Display , 5, volume up , power
                                          • brithepi2k
                                            Sony KD-65XE8596 no standby light
                                            by brithepi2k
                                            I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                                            cheers...
                                            09-06-2025, 02:22 PM
                                          • rabbituk
                                            Sony HCD BX7700dbi CMT flashing standby
                                            by rabbituk
                                            I have got a Sony HCD-BX7700dbi that isn't worth a lot but I'm keen to learn how to repair and would appreciate some help with my train of thought. The protection circuit is kicking in and the standby light is blinking. It goes into protection mode within a second of powering it on.
                                            So far the relay on the power board that enables the main transformer clicks on and then off when powering on the unit. Looking at the schematics, the permanently enabled power rail called 'unreg sub' provides about 13.5VDC. Where the power comes into the main board on connector CN303, there is a diode...
                                            02-11-2025, 05:05 PM
                                          • androripara
                                            Sony Bravia 55HX820 - 4 times blinking red standby led
                                            by androripara
                                            i am trying to repair a Sony KDL-55HX820 led TV which is throwing error code 4 (standby led flashing four times).
                                            I followed the troubleshooting flowchart at page 69, and between pin1 and pin7 of CN6002 i am reading 1.91V so i guess i can rule out the B Board as the culprit.
                                            Before ordering new G* Boards (by the way, should i change both? it is not specified in the manual) i wanted to try and do more advanced troubleshooting since i've read in other threads people resolving their problems on the 46/55 HX 820/823/825 models by replacing the Samsung led...
                                            10-19-2023, 05:16 AM
                                          • denisten
                                            Sony STR-DB870QS standby transformer
                                            by denisten
                                            Hi everyone, i am a newbie here and i hope i will find the help i need. I have the above mentioned receiver with standby transformer's primary coil damaged. I have searched the net without success to find any tech data about this transformer. I have only the Sony part number1-437-313-11 and TAM Malaysia M0126. I guess i could find replacement for it, but i need to know the secondary coil voltages and VA. It is 220v on the primary. It has 5 pins on the secondary, the outer two are not used and i have 6.5 ohms between pins 2and 4, 3,9 ohms between 2 and 3, and 3,6 ohms between 3 and 4. Can someone...
                                            04-14-2023, 03:24 AM
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
