Piva 15" LCD/DVD/VGA runs while power button depressed
  • jmfox
    • Jun 2009
    • 12
    I had it apart a while back and have images, but they are not very clear in details.
    This is an "Anti-Shock" portable device and I ran it in a vehicle with the provided DC power cord as both a TV/DVD player and secondary display for my laptop. It's is really nice and convenient, so I would like to repair it if possible.
    I found nothing obvious when I had it apart and inspected it. Except a ugly looking solder joint on the bezel control board (corrected). Also swapping power supplies (external like many laptops) had no effect.
    Does anyone have any ideas on where to start? I have a couple cheap DMMs and follow directions quite well
    I'll pull it apart again and carefully recheck and inventory the caps... just to double check.
    Jim
  • Krankshaft
    • Jan 2007
    • 2328
    Re: Piva 15" LCD/DVD/VGA runs while power button depressed
    If it runs when you press the power button shine a bright flashlight on the LCD.
    If you see a faint image check the inverter. The tiny PCB all the way to the right with the purple (probably Hermei) cap on it.
    • jmfox
      • Jun 2009
      • 12
      Thanks for the quick reply.
      The back light works fine. What I mean by runs is that it starts up and if in DVD mode will boot to the menu of the DVD in the drive and then not respond to the remote. So unless the DVD auto plays, say after a delay it will not continue, as it will not respond to the remote while the power button is depressed. As soon as I release the power button on the bezel it powers down, I can almost select an option on a DVD first but it will power down.
      Same thing in any other mode.
      Tuner mode - starts, displays whatever channel it is on, and will not respond to the remote. Powers down when the button is released.
      VGA Mode - Same, which is almost OK but eventually you need both hands for something
      It will start from a power up command on the remote, but then depending (it seems) on how hot or cool the device is, may either reach a DVD menu or just start booting the DVD before it will recycle and retry. It will recycle the power state like this endlessly. The only thing that seems to happen is the cycle gets shorter the hotter it gets. Note: I never let this go on longer than about 4 -5 minutes.
      I suppose I can open it up and put the boards in a the freezer to see if they then start and run. Then when it starts again do one board at a time.
      Jim
      • Krankshaft
        • Jan 2007
        • 2328
        Check all of the boards over for cracked solder joints.
        • themosttogain
          HP Envy 13-BA1565na with intermittent power button
          by themosttogain
          Hope someone can give me some suggestions on this because i'm at my wits end with it...
          I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
          Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
          07-12-2024, 03:03 AM
        • TimeRabbit07
          Asus FX517ZC charges but power button does nothing
          by TimeRabbit07
          Hi all!
          I've got an Asus FX517ZC on the bench at the moment and I just can't figure out what's going on with it.
          Here are its various numbers and identifiers:
          Model short: FX517Z
          Model long: FX517ZC-HN114W
          SN: NANRCX01S57842E
          CN: 3SDB 12M
          MFD: 2022-10
          Motherboard model: DA0NJLMBAE0 REV E
          Symptoms:
          The laptop's charge light comes on, but when the power on button is pressed nothing happens. No fan spin, no caps lock, no screen or keyboard backlight, nothing.
          History so far:
          The...
          09-04-2024, 05:48 PM
        • reessi
          Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
          by reessi
          With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
          No corrosion any where!
          Tried a replacement power button off ebay and the same.
          Very occasionally it will work with the power button connected!
          Same results with or without the battery.
          Can it be a fault with the Audio board or the mainboard?
          The touch Id assembly connects through the Audio board first then to the Mainboard.
          Flex...
          06-26-2024, 03:31 PM
        • Darren Hibbert
          MacBook A2179 Audio board+Power button boardview & schematic needed
          by Darren Hibbert
          Hi.
          Long shot but does anyone have a schematic & boardview for the audio board+power button on a Macbook A2179?
          There is a shorted cap on mine and I need to know if I can safely remove it or whether I need to replace it and with what capacitor.
          Many thanks. ...
          Yesterday, 02:38 PM
