Difficult question for 17MB82s
  • joker250003
    • Jul 2014
    • 4
    • Greece
    I have a 40'' TV using the cursed 17MB82S board and my problem was the "red light flashing". I found a pre-used 17MB82S near me and i decided to buy it from e-bay. When i put it on the TV worked just to find out the picture was upside-down and the resolution 800X600 or lower. Then i checked the card i bought and it wasn't exactly the same in fact it was for 42'' TV. I couldn't solve this even from the service menu. Anyone knows if i can reprogram the board to work with my 40''. set?
  • ducky29
    • Dec 2015
    • 369
    • Europe
    Re: Difficult question for 17MB82s
    You have to flash the exact firmware for you tv by usb, or use a programmer and program a dump that fits your chassis+screen.You need a soldering gun and a programmer. The memory chips in the 17MB82S are usually U10 and U12. Also have in mind that you might have no reception or audio based on the dumps that you use. If you cannot find help elsewhere I can order the firmware by usb for 10$.
    • joker250003
      • Jul 2014
      • 4
      • Greece
      So may i use the U10 and U12 of the 40'' main board supposed it was not the problem of light blinking? Also USB drive doesn't seem to read
      • ducky29
        • Dec 2015
        • 369
        • Europe
        Yes you may use the u10 and u12 chips from the previous board.
        • pcbmaniac
          VESTEL 17MB82S not working only red led working
          by pcbmaniac
          Dear friends,
          i do have a VESTEL 17MB82S not working. Here is the story:
          First, when i give power on tv, red led lights after some blinkings and i've noticed that picture apears but no backligt at all (i use a small light to see it).
          Then i do flash with a FAT32 USB stick, the upgrade_loader.pkg file with the known OK button method. After that, the TV stops and when i press the ON-OFF button from remote control, the red led goes on but no backlight no picture at all.
          I do took off the 2 flash IC's U10,U12 try to read them with flash programmer, but i get "Error...
          10-15-2023, 03:01 PM
        • Davy no Caps
          Vestel 17MB82S EEprom dump required
          by Davy no Caps
          First time trying to fix a TV for a friend, it's a Bush DLED32165HD.
          Power Board - 17IPS11
          Mainboard - 17MBS82S
          Panel - VES315WNDB-02
          Red blinking standby light is on steady, press power button on remote and light flashes 7 times then stays steady, press power on remote again light flashes 10 times and then goes off.
          Checked all the voltages on the power board inc backlight circuit, they all read ok and are stable. Backlights tested with backlight tester and all work fine (2 strips x11LED on each).
          No picture, backlight or sound just blinking...
          06-06-2025, 03:22 PM
        • snoptel
          Another tango with the 17mb82s
          by snoptel
          Hi guys,
          I have a cheap LCD TV with a VESTEL PS and a 17mb82s board.
          Outta de blue the led flashes red 7 times, the back light comes on for a second and starts this loop over again.
          Been reading about re-flashing the eprom chip and how they have to be frozen in order to load the USB.
          Any input from the fellow hackers in the forum?
          Thanks.
          04-08-2022, 10:20 AM
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
        • eniac22
          Vestel 17MB82S Firmware
          by eniac22
          Hello, i need firmware for Vestel 17MB82S, panel VES315WNDA-2D-N11....
          02-24-2022, 10:48 AM
