sharp LC-60LE644U main board problem.
  • sputnikoff
    • Feb 2016
    • 203
    • canada
    I have had a number of LC-60LE644U with main board problems.The set sometime turns on and other times just back lights.I haven't troubleshooted the module as the replacement is 62$ so was more economic to swap out.Seems like main processor is issue.Has anyone had in depth experience with this particular model?
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    Re: sharp LC-60LE644U main board problem.
    hi
    did u fix issue?
    i have same model tv
    tv sometimes powers on ok but sometimes when powered on the screen flickers and does some funky distortions and then image kicks on ok but then after about 15 min the image fades away and then no image and backlight stays on..it seems the lcd panel is powering off...and the power indicator light stays on fine
    during this time i can hear a buzzing sound (faulty component such as capacitor or transormer)) coming from back of tv..
    i have no taken apart yet
    my initial guess is power supply or tcon but with these newer tvs it can be anyhting...
    • shelby5041
      • Feb 2009
      • 1505
      update..took tv apart today....as i figured it was not main board issue
      it was bad capacitor on power supply as i thought
      replaced 470uf cap..tv fixed
      • advant
        by advant
        02-03-2020, 12:25 AM
      • Dani_2024
        by Dani_2024
        10-28-2024, 05:06 PM
      • jb_Bak
        by jb_Bak
        CN6401
        Pin 01 NC
        Pin 02 NC
        Pin 03 "BL_ON": 0V
        Pin 04 "N/C"
        Pin 05 "STBY 3.3V": 3.5V
        Pin 06 "GND": N/C
        Pin 07 "AC_OFF"...
        09-27-2021, 04:52 PM
      • JDC
        (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
        by JDC
        ONN 100012588
        Issue: No Power, Then Rebooting After Main Board Change
        Short answer: replace main board and power board
        Technical answer: replace main board and Q306 & Q307 on power board.
        Long answer:
        TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
        07-15-2022, 07:39 AM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
