TX-L50B6B Failing to start up backlight flicker
  • Loading.......
    • Jan 2019
    • England
    Hi.
    I have a Panasonic TX-L50B6B (Vestel, I beleive)
    TV tries to start up, during this time the backlight will flicker every second or so
    After a couple of flickers TV turns off and red light flashes every 4-5 seconds.
    I have removed the back and gave a visual inspection and everything looks fine to me. This TV has a what I believe to be a Backlight Inverter Board, I unplugged this and applied power to set and the set still turns off after the same amount of time (without backlights obviously)
    Having read a few threads it seams it may be a backlight problem which is why I unplugged the inverter as I thought no inverter would rule that out (happy to be proved wrong)
    I have no real electrical background Knowledge but I am not a complete idiot and do realise what power is where and to be careful. I may further add that I try to repair all of my own household electrical items as I am a tight Git.
    Thanks in Advance for any posts relating to this and I have came here as you guys helped me about 10yr ago, during the Samsung bad capacitor period.
    Thanks Guys.
  • nomoresonys
    • 12206
    • U.S.
    Re: TX-L50B6B Failing to start up backlight flicker
    One blink of the power LED indicates a problem in the inverter circuit.
    • nomoresonys
      • 12206
      • U.S.
      One there for 25+10, may be some cheaper, just stopped at first one I saw, don't know if it will fix but that's what 1 blink code comes up with. As always triple check to try to insure a match whenever buying a part, maybe check the resistors on the board with a multimeter, it may be a 50 cent fix rather than 35 pounds. https://www.ebay.co.uk/itm/INVERTER-...aSl:rk:26:pf:0
      • nomoresonys
        • 12206
        • U.S.
        may want to check Scotty16's thread there, just a few rows down. https://www.badcaps.net/forum/showthread.php?t=51587
        • Loading.......
          • Jan 2019
          • England
          Hi NomoreSonys.
          Thanks for the replies and suggestions.
          After having a good look around the site and the net, it seems these are terrible for backlights going. I have read a few where the inverter board was replaced and problem stayed the same. I think I will strip out the boards and tip it as I never know what I will find in my job and I quite often come across TV’s.
          My other TV is a 55 inch Logik (vestel) I repaired that by replacing a few diodes after reading a thread or two on here, it owes my about £1 which is just over $1 in today’s rates ��
          Thanks again Friend and I will nip in every now and then to pick everybody’s brains.
          Keep safe Pal and best wishes from the UK ����
          • nomoresonys
            • 12206
            • U.S.
            These might respond well to the current mod. here where they switch out a couple resistors. https://www.youtube.com/watch?v=ogtfojsIZK8
            • nomoresonys
              • 12206
              • U.S.
              Originally posted by Loading.......
              Hi NomoreSonys.
              After having a good look around the site and the net, it seems these are terrible for backlights going. I have read a few where the inverter board was replaced and problem stayed the same. I think I will strip out the boards and tip it as I never know what I will find in my job and I quite often come across TV's.
              My other TV is a 55 inch Logik (vestel) I repaired that by replacing a few diodes after reading a thread or two on here, it owes my about £1 which is just over $1 in today's rates ��
              Thanks again Friend and I will nip in every now and then to pick everybody's brains.
              55 inch tv for a dollar, very nice find.
              • triplefour
                by triplefour
                09-13-2023, 10:43 PM
              • DanPoka
                by DanPoka
                02-15-2025, 05:05 AM
              • Comp_Pro
                No Backlight Macbook A1990 820-01041
                by Comp_Pro
                Hello all,
                Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                Tests performed:
                There is no backlight even with a good screen.
                Backlight IC is receiving the correct support voltages.
                Fuse F8400 ok
                Current sense resistor R8400 ok
                Backlight IC is receiving 3.3V on enable pin.
                Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                Backlight IC receiving 5V from PP5V_G3S
                Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                05-06-2024, 10:23 PM
              • fixit007
                Samsung flicker - BN44-00932T board or else?
                by fixit007
                I picked up this TV that the prior owner said - just died.
                Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
                Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
                Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
                05-04-2024, 06:14 PM
              • jimbofz
                lg 32LC46 backlight inverter board fault
                by jimbofz
                Hi this oldie had no backlight .after replacing caps on 24v rail ,
                still no b/l this uses inverter type:1315 B1-16A,
                im sure ive come across the same inverter in a samsung possibly le32r88bd ?
                all t/x in board test ok ,so i fitted 15k and led to pin 4 of oz964gn ic
                this allows protect to be temporary overridden.
                b/l now comes on
                but the left hand side of pic is gradually darker than the right side
                i have the cct for the tv
                but it does not have inverter cct.
                i opened it up to inspect the ccfl tubes
                and they dont have any...
                12-19-2021, 06:58 AM
