LG 55EC930V OLED - 3 Second Power No Display
  • Dac12
    • Aug 2025
    • 31
    • Uk
    #121
    Please ignore this photo completely wrong ic sorry
    • Dac12
      • Aug 2025
      • 31
      • Uk
      #122
      Originally posted by Diah
      don't miss up with SoC soldering.. .. i wrote MB, not SoC... yours MiCOM firmware distributed because of playing with microswitch which had nothings to do.... try disconnect pin 6 of MICOM and try IN_STOP
      But I'm confused Diah has advised to disconnect pin 6?
      • Diah
        • Feb 2013
        • 6440
        Originally posted by lotas
        Here is micom ic3000, but the remote control will not work if you cut the track to the 6 pin
        RC will remain to work... this is SOS rail... RC took from other rail the function
        • Dac12
          • Aug 2025
          • 31
          • Uk
          #124
          I'm confused because Diah has advised to disconnect it
          • Dac12
            • Aug 2025
            • 31
            • Uk
            #125
            Yes thank you I understand now. But last question of many how do we disconnect this pin 6?
            • Diah
              • Feb 2013
              • 6440
              just pull it up from circuit
              • Dac12
                • Aug 2025
                • 31
                • Uk
                #127
                Lol you mean heat it up and pull leg up? Or can the sensor be soldered off?
                • Diah
                  • Feb 2013
                  • 6440
                  use thin soldering head with flux,,, don't heat the chip in total
                  • lotas
                    • Jan 2016
                    • 4754
                    • Russia
                    #129
                    Ok, let's see how the remote will work after removing 6 pin. The ir sensor and keyboard (joystick) are connected to this micom.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4466
                      • Italy - Milan
                      #130
                      "yours MiCOM firmware distributed because of playing with microswitch which had nothings to do..."
                      and this sounds as the same old attack to others, every now and then it would be pretty to see from this individual documentation at support of these funny stories.. i will not support Dac12 more because is a novice and trends to listen funny technicians.. good luck (especially when you'll have to reattach virus size pin to a chip with super glue... my god..
                      • Dac12
                        • Aug 2025
                        • 31
                        • Uk
                        #131
                        Please don't be offended, I admit i am a novice first time on a electronics board. What would you suggested?
                        I can't freeze screen ribbons as you suggested because I cant get access to them.
                        I rely and value all your opinions but as you can clearly see I am at a disadvantage due to no electrical background
                        • Diah
                          • Feb 2013
                          • 6440
                          Lotas, SOS will but whole TV in lamm RC, Keyw´s and send PSu to shutdown , MICOM as guard beside sequences of the operation. we have here threat where we did deep inspecting on MICOM at same model.
                          BTW : you can see its IN SOS signal not out
                          Davi.p:
                          just say in clear words did you have OLED repaired ?? no more or less... dont act you know the issue and you will not said it to owner of this problem... this is child play... be adult as yours age. .
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4466
                            • Italy - Milan
                            #133
                            Sorry dAc12, i will enter back the discussion when the King of Oleds finishes his efforts, i do not accept more bickering, i never own an oled, but i'm free to explore oled threads, maybe in some one country is forbidden by law..
                            • lotas
                              • Jan 2016
                              • 4754
                              • Russia
                              #134
                              IR + KEY ---- MICOM
                              • Diah
                                • Feb 2013
                                • 6440
                                IR + KEY ---- MICOM
                                lotas ,,, you are expert.. look on the diagram pin in and out.... in u can take it out... out pins are funktion
                                • lotas
                                  • Jan 2016
                                  • 4754
                                  • Russia
                                  #136
                                  Well, everything is correct, the IR sensor receives a signal from the remote control, and from this IR sensor the coding signal comes to the input 6 pin. MiCOM and MICOM gives the command to turn on the TV...
                                  • Diah
                                    • Feb 2013
                                    • 6440
                                    plese stop- as i cant laugh any more..... search please my post over oled and u will finf the correct answer how we did prove it,
                                    • lotas
                                      • Jan 2016
                                      • 4754
                                      • Russia
                                      #138
                                      Ok, OP cut 6 pin. on MICOM and give any command from the service remote control and we'll see the TV's reaction, and we'll all have a laugh at the same time.
                                      • Dac12
                                        • Aug 2025
                                        • 31
                                        • Uk
                                        #139
                                        We will do just give a couple of days, it's to small to see.
                                        • Dac12
                                          • Aug 2025
                                          • 31
                                          • Uk
                                          #140
                                          I don't understand- do you think we should not cut pin 6?
                                          • learnmore
                                            Lg oled 55ec930v automatically turns off after 1-2 seconds
                                            by learnmore
                                            Hi Community,
                                            I've got the above model that activates the relay (clicks) and powers on the LG logo power light on when turned on. It then almost immediately turns off. I not noticed any image on the screen or heard any sound during this brief period.
                                            Checks show:
                                            3.5v on SMPS on (in off state, no other voltages present incl pwr on)
                                            On pressing power button > the 3.5 pwn on voltage, 12v and 24v lines appear on the SMPS connnector between the main the SMPS but then all drop the zero in 1-2 seconds
                                            Disconnecting 24 to TCON connector and powering on shows...
                                            05-08-2024, 02:42 PM
                                            ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                            This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 04:30 AM
                                            Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 07:12 AM
                                            Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED 9MF-E2USBB4SH boardview and 14 OLED 9MF-E2USBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 06:40 AM
