Philips 480FH6300 logo and reboot ...
  • Terrotiste
    • Feb 2018
    • 32
    • France
    Hello everyone
    I have a new Philips TV to depanner reference 48pfh6300 / 88 ...
    When TV is plugged in, lights up and displays the Philips logo, then turns off and on again and this at the end ...
    I flashed according to the files that gave me by philips, it seems he takes the firmware on the USB key, but when I turn it on it does not propose to update the tv ... it turn in a loop on the logo
    Does anyone have an idea, knowing that this tv is new ...?
    Thanks for your help very much
    Cordially
    Jerome
  • G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo
    by G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
    It does power up when pressing the power button.
    I already try the power button while plugin the plug with no result.
    Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
    Could this be an PSU or eMMC issue ?
    07-19-2025, 03:43 AM
  • alfonzzo
    Philips TV 40PFL3148H/12 keeps restarting on the logo
    by alfonzzo
    My Philips TV 40PFL3148H/12 keeps restarting as soon as the Philips logo is displayed, as soon as I plug it. The remote doesnt have any effect on it anymore, plus no red light on the tv panel as usual.
    After contacting their support, they sent me a file to update the firmware from usb but without success (8gb 2.0 drive formatted in fat32).
    Then they told me that it was a hardware problem.
    Here is a video of the problem : https://streamable.com/8ixf1u
    Thanks for your help...
    08-10-2022, 09:00 AM
  • Xristakis795
    samsung ue40d503problem reboot logo only when i have input signal from hdmi and tuner
    by Xristakis795
    hi to all
    i have the above model ue40d5003
    the damage was definitely caused in my case by a generator that I installed burned the protection at power supply of tv and created the following problem
    when I have not connected the antenna, any input source lights up normally i can insert on the menu and the tv doesnt reboot
    when I connect,the antenna or hdmi signal however, when it goes to show an image, the image appears momentarily and then restarts appears the logo and the same again.the lights of standby blinking continously
    Can you tell me from your experience...
    02-09-2023, 03:17 PM
  • spice_disc
    Vizio TV M50-C1 reboot cycle and static on screen
    by spice_disc
    I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
    The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
    09-08-2024, 02:37 PM
  • Verlengsnoer
    Bios splash/logo change
    by Verlengsnoer
    at firs, i hope this is the right place to post my question.
    Im looking for a tool to change the bios logo.
    everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
    i know that HP has a build in option to change the splash logo.
    but i want to change the manufacturer logo to an own logo.
    I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
    10-28-2022, 09:52 AM
