Samsung Plasma PS42C451 no picture, good sound
  • dkneyle
    • Dec 2013
    • 445
    My neighbour reported he just turned it on, had sound, no picture. I can confirm there is no indication of any illumination whatsoever from the screen. All voltages seem to check out OK: Vs, Vscan and Ve.
    I replaced the Y-Sus board figuring it would be an easy fix. No change whatsoever.
    The telltale LED is happily flashing on the logic board. Audio output is OK.
    I feel I'm missing something simple here? All suggestions much appreciated.
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Samsung Plasma PS42C451 no picture, good sound
    Run the test patterns.
    • dkneyle
      • Dec 2013
      • 445
      Have placed jumper in position to attempt to run the test patterns. In a darkened room I can see the occasional VERY dim white-wash screen as it runs through its patterns.
      All voltages to the Y-Sus board look good (this is a 2nd-hand replacement board that is supposedly good).
      We have a good heart beat LED signal, suggesting probably nothing wrong with Y-Sus or X-Sus boards?
      I disconnected the X-Sus board and then there is no sign of life from the panel. Heart drops back to about 1 per 5 seconds as you's expect.
      I'm at a bit of a loss and need some guidance from a plasma guru.
      Do you reckon control board has died?
      • R_J
        • Jun 2012
        • 9625
        I would check the fets on the x-sus, That board looks familiar
        • dkneyle
          • Dec 2013
          • 445
          Sorry, I'm an idiot. There is a very small power connector going from the Y-Sus board to the z-Board running along the bottom of the screen and I hadn't put it back on.
          So test patterns run all OK. Resetting TV with jumper removed I again have sound but no image.
          Control board?
          • dkneyle
            • Dec 2013
            • 445
            From what I've been reading, if the test patterns are OK then the Logic Board will also be OK. Leaving the Mainboard I guess?
            • tvtimmy
              • Mar 2015
              • 1160
              • usa
              If you have good test patterns, the main board is bad.
              • dkneyle
                • Dec 2013
                • 445
                Before deciding to seek out a replacement mainboard I did what I should have done first. I reseated the video signal cable between the mainboard and the logic board. I also reseated the mainboard power cable. Everything came good afterwards. I looked carefully through my mag lens at those cables and they looked perfect before I reseated them. Some marker-pen writing on the mainboard suggests it has been changed over previously. I just wonder if there was some grime on the contacts? We've also been having extraordinarily hot weather here in Oz lately. Expansion and contraction might also explain something. Anyway, all going again and post closed!
                • tvtimmy
                  • Mar 2015
                  • 1160
                  • usa
                  Great ending!
                  • Mgiffune
                    by Mgiffune
                    06-09-2024, 10:28 AM
                  • TR103
                    by TR103
                    - it keeps rebooting
                    01-22-2025, 04:12 PM
                  • Ierwin
                    by Ierwin
                    05-13-2025, 03:31 PM
                  • jchang
                    Samsung UN70NU6900F no picture and no sound
                    by jchang
                    Hi all
                    I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                    Symptom:
                    No picture no sound.
                    When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                    No sound at all.
                    What I tried:
                    1. I tried unplugging the left or right ribbon...
                    01-09-2023, 06:28 PM
                  • Dodgethis
                    Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                    by Dodgethis
                    Hello all,
                    This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                    09-11-2024, 07:39 AM
