Samsung UN55D6420 55" LED Turning on and off
  • schloofy
    • Jan 2019
    • 5
    I have scoured this forum and have checked the following:
    Caps - none visually burst or bulging
    Solder - I've soldered the most common locations of cracked solder. All appears good
    The main board and t-con both look good as well.
    Cables all good, no bent pins, all plugged in tight.
    Eliminated frame mounted controls - made no difference.
    LEDs are all functioning.
    Good picture with computer connected via HDMI.
    This unit is turning on just fine. I can control it with the remote or the frame mounted controls. If it's left on, it will turn off within 30-90 seconds, sometimes longer, but never longer than five minutes. After the TV clicks off, it immediately clicks on again and the above cycle repeats.
    When the power cord is disconnected, the relay clicks, then a couple seconds later it will click twice and then clicks twice again before it's completely off and quiet.
    I'm far from an expert, but I suspect a bad cap, but like I said, no bad caps are visible. I scoured the board with a magnifier and can detect nothing.
    Any help to narrow the problem down would be appreciated.
  • nomoresonys
    • 12276
    • U.S.
    Re: Samsung UN55D6420 55" LED Turning on and off
    Try heating the power board with a hairdryer, focus on one small area at a time including all the caps, some of the caps can be ceramic, like the little blue ones, don't forget to heat up those optocouplers too/ usually 4 legged components. See if tv comes on.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8327
      Did you read this?
      https://www.badcaps.net/forum/showthread.php?t=38851
      • Sevenqi
        • Jul 2011
        • 292
        I had the same model same issues, end up replaced the main board fix it.
        • schloofy
          • Jan 2019
          • 5
          Yes, I did. Read every comment in the long thread. Gave me some ideas, but none of them panned out.
          • schloofy
            • Jan 2019
            • 5
            That is one thing I haven't done. Will try and report back results.
              09-07-2024, 05:50 AM
              09-06-2024, 11:40 PM
              09-06-2024, 08:40 PM
              Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
              This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              09-06-2024, 06:20 PM
