TV LG 22MA33D-PZ - Nand flash data file
  • Smartec82
    • May 2015
    • 25
    • Portugal
    I needed the flash nand data for a LG 22MA33D-PZ TV with main board EAX65359603.
    Thank you if anyone has it and can share it.
  • Smartec82
    • May 2015
    • 25
    • Portugal
    Re: TV LG 22MA33D-PZ - Nand flash data file
    Already solved, I managed to get the content of nand flash.
    The fault was: the standby light was blinking without stopping and the TV did not turn on.
    • Spider1211
      iPhone XS Data recovery from NAND flash
      by Spider1211
      Hey guys, I have an iPhone XS which came in as dead. The phone was not worked on before (I was the first to open it). After diagnosis (Splitting board, etc) it's confirmed to have a shorted PP2v63_NAND line.
      Removed the NAND flash and short is gone on the board. Measuring directly on the NAND, there is about 2 to 15ohm to ground.
      Is there anyway of backing up data externally in such cases (Client has some very important files and no back ups)?
      08-22-2022, 09:22 AM
    • abajor
      Canon VIXIA HF S10 A read data from inernal flash memory.
      by abajor
      Hello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
      Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
      The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
      I think my best shot is to figure out a way to read the internal flash memory outside...
      07-20-2024, 12:04 AM
    • dragometin
      Hitachi 40HYC42
      by dragometin
      TV Model: Hitachi 40HYC42
      Power Supply: 17IPS71
      MainBoard: 17MB95M
      Panel: VES400UNDS-2D-NO3
      When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
      I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
      Is there any variants on 17IPS71 power supply's?
      UART output pins 10 and 12 on scart connector:
      Code:
      12:24:04.595
      08-08-2024, 05:53 AM
    • kenzo2
      Please help me file Dump Nand Macbook Pro A2159 2 Nand 512GB
      by kenzo2
      I need dump file for nand A2159 512GB with 2 Nand chips >.I upgraded 128gb to 512gb..I use P13 there are only 4Chips...
      I need dump file MACBOOK PRO A2159
      TSB4232(256)
      TSB4229(256)
      Thanks​
      01-11-2025, 04:18 AM
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
