Insignia NS-LCD37 Black looks green
  • Gorrillasnot
    • Dec 2013
    • 316
    Pitch black scenes look green. other colors and shades of grey seem OK.
    From the bit of searching I have done most suggest reseating the LVDS cable which I plan on trying, but if that doesnt help what is likely the problem..bad t-con and/or panel?
    thanks
  • aaronwt6
    • Apr 2013
    • 855
    • US
    Re: Insignia NS-LCD37 Black looks green
    Looks like a gamma issue. Most likely a T-con issue and my guess is that you have one with an AS15 chip on it (highly prone to failure). I'd need to see pictures of your T-con to determine. This model can have 1 of a dozen or so T-con boards.
      • 12206
      • U.S.
      Test your tcon, here's a nice how to if needed: https://www.youtube.com/watch?v=eZZwb35ou_Y
      • Gorrillasnot
        • Dec 2013
        • 316
        I ended up buying a T-Con on eBay and it helped very little with the green problem.
        Before a black screen was totally green now it is black with lots of green dots in it.
        With the eBay T-Con I have a new problem that whites now look light purple/pinkish.
        Also with both T-Cons I have a vertical line on the left side of the screen and several diagonal lines.
        I will test the t-con when I take the TV back apart (rookie mistake..put it back together too soon).
        The model of my T-Con is CPT370WA03C 4C2..I attached a pic of 1 like mine from shopjimmy.
        thanks for the link to the testing video
        • Gorrillasnot
          • Dec 2013
          • 316
          I returned the ebay t-con and bought another 1 from a different seller on ebay.
          The second t-con was listed as a CPT370WA03C 4C2, but when I received it it was in fact a 4C and not 4C2 (part number in the white box on the t-con) needless to say I tried it anyway, but still have the same problem.
          Could not being the exact same part number be the problem?
          I'm thinking the problem is with the board that attaches the t-con to the pannel in which case probably is not fixable?
          I forgot to say in my original post how this problem got started. My better half used a vacuum to dust the back of the TV and right after is when the problem started. Must have killed the TV with static discharge.
          I tried watching that YouTube video about testing t-cons but was unsure where the correct location was for the test points on my t-con..I dont see anything labeled vgma..
          thanks
          • Gorrillasnot
            • Dec 2013
            • 316
            I tried measuring all the test points I could find on the t-con. they all showed voltages ranging from 1.1v all the way up to 11.2..I have no idea what the correct values should be as I am a noob.
            I tried disconnecting 2 of the ribbon cables at a time from one side of the t-con and powering on.
            With the left 2 cables unhooked the left side of the screen starts up in what looks like some kind of a greyscale pattern that eventually turns all black while the right side is green (should be black).
            With the right side disconnected the right side is solid black and the left side is white witch a bunch of vertical lines.
            Does this sound like a bad panel? or maybe something on the driver boards that are tab bonded to the panel? or could it still be a problem in the gamma circuit?
            thanks
              • 12206
              • U.S.
              Could try a factory reset, might not help but won't hurt any.
              • Gorrillasnot
                • Dec 2013
                • 316
                Factory reset didn't help..also saw some youtube videos that suggested reseating the LVDS cable, tried that and it didn't help.
                I think when the vacuum was used to dust the top vents in the TV that it must have shorted something in the panel or the board(s) that are tab bonded to the panel.
                anything else to try?
                thanks
                  • 12206
                  • U.S.
                  Don't know, I usually blow mine out with a leaf blower, never had a problem like this.
                  • budwich
                    • Jul 2015
                    • 3097
                    your "vacuum person" might have done some "window washing" also... maybe :-(
                    Normally, when one disconnects a cable (or two) from the tcon to panel, that disconnected side gets "pure white screen" while the other side would continue to show a picture. You almost get that from one of the "tests" but the opposite side is not close.
                    It would appear that there are issues with the edge boards which are connected to the panel. You might want to inspect them to see if you notice any signs of "contamination" in and around contacts especially near the panel. It is not looking good though.
                    • Gorrillasnot
                      • Dec 2013
                      • 316
                      thanks budwich.
                      Yep I'm going to test the panel driver boards (or atleast to the best of my lack of ability lol).
                      While trying to search for info on youtube i've seen videos showing bypassing the gamma chip using jumper wires..unfortunately the audio is not in English or I'd give it a try as a last resort.
                      • arctor
                        samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
                        by arctor
                        hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
                        04-26-2025, 05:22 AM
                      • jimjoe123
                        LCD TV Green/Pink screen problem
                        by jimjoe123
                        I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                        Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                        Then each time...
                        02-23-2020, 01:29 AM
                        HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                        This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                        09-12-2024, 02:00 PM
                        MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black N4000 Specification for Upgrade or Repair
                        This specification for the MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Cubi N 8GL-063DE/N4000/4GB/W10P/Black boardview and Cubi N 8GL-063DE/N4000/4GB/W10P/Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                        09-12-2024, 01:58 PM
                        Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                        This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                        09-07-2024, 05:00 AM
