m#lc-40le810un.customer complaint dead set.no led,audio,video,backlights.no signs of life.fuses ok & 168v raw b+ on caps c7800a & b.5v standby out of power supply to main.3.3v out of main.no other voltages.not much in manual at techdata.suspect no turn on from main but also could be power supply.any ideas on pinning it down to one board?
					sharp aquos crap shoot?
			by scubacamperI found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
 Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
 when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
			by sefosterI have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
			by jonah1024Hello!
 I'm a few days old into this TV screens repair universe so please bear with me.
 Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
 - I did the classic unplug and hold power button to discharge the caps but it didn't help.
 - I did a factory reset as well...5 Photos
			by klassicHi community,
 I will describe my problem with a TV in those short following terms to be the most precise :
 What i have :
 Sharp Aquos LC-60LE635E
 power board DPS-162KP-1
 main logic board QPWBXF733WJN2
 symptoms :
 white led light logo at startup,
 after 2 minutes, blinking 3 times a row, repeating
 no backlight (and apparently no picture, checked panel with flashlight)
 no startup sound
 powerboard investigations :
 1-2 PNL : 0v
 3-4 GND
 5-6-7-8 UR : 13.15v
 9-10-11-12...
			by foxyUKCan anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
 The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
 There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
- Loading...
