KOSS with audio that comes up 1/2 hour later after on.
  • Wizard
    • Mar 2008
    • 2296
    I had interesting day trying to debug this KOSS 27" set (Don't remember the model but I'll get it on monday and post new note about it.)
    Well, Unit works fine aside from no audio till volume maxed out and you get pops/barks from the speakers with signal in.
    1/2 hour later audio quickly comes up staring gutteral sounding gradually good.
    Taking apart the chassis is interesting, you had to take the black box with the analog inputs off first then cabinet back off. Then have to take tinbox off the mainboard to see what the problem is. Mainboard only have the VGA and DVI inputs. Other inputs is through this black box.
    Audio amp section is on mainboard itself and has audio power feed thru domed capxon that also had broke the connection inside the cap that leg wiggles freely. Duly replaced that. No change!
    To troubleshoot more, I had to unbox the die-cast black box and get die-cast base off the analog daughterboard so I have more room to access around the daughterboard, I was in luck as you will see.
    Heated the PWM audio amp section made audio come up, but freezing spray didn't quite gave the result. Went wide with the spray made audio go away. Narrowed to the -8V linear regulator (LM7908 type in SMD factor). with a cold swab dab the regulator's tab gave instant results. WHAT?! -8V needed in this chassis? That smacks of bad design. I have not found the source of circuit that converted positive voltage to negative voltage as this PSU does not have -V supply (all 5V and 12V only, 24V for lamps only).
    I knew from my previous study in the Art of Electronics book there is many ways to generate negative voltage supply. So no worries to locate the source of this dang thing on this mainboard because I needed to see where this is coming from.
    Stacking the boards 3 deep is sloppy. Mainboard then this daughterboard with tiny sub-daughter board on it. Increases the cost and more failure points, and quality of PQ is terrible for this even mainboard does have 2 big chipsets as that two should implies video processing grunt but this was not the case as I sadly discovered. Uses two Genesis chipsets (one BGA, one gullwing 208 pin type).
    I had so much issues with lack of attention to reliablity and servicablity in generic Plasma & LCD TVs is appalling.
    Cheers, Wizard
  • Mirenia
    Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
    by Mirenia
    I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
    I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
    In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
    The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
    03-30-2025, 06:47 AM
  • orcic
    MASTER TL240 and new mainboard LW36BKC01
    by orcic
    I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
    The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
    After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
    Now I have some doubts about how to connect the new mainboard to the old power supply.
    First of...
    05-12-2023, 08:10 AM
  • Malva
    Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
    by Malva
    I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
    Mainboard model: EAX65684604
    PCB marking: EBT62954607
    SPI chip: Winbond W25X20CLNIG Problem description:
    Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
    After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
    • I bought another
    06-25-2025, 02:07 PM
  • Devonavar
    Vizio M43-C1 - How closely do I need to match the mainboard number?
    by Devonavar
    I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
    I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
    Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
    So, I've ruled out the PSU for now.
    The reboot loop...
    08-14-2022, 08:46 PM
  • l0lhaxz1
    QN65QN90A - Mainboard MLCC failed - now bootloop
    by l0lhaxz1
    Hi
    I have a QN65QN90A which was purchased around launch I guess making it about 1.5-2 years old... had been working fine until a few days ago, simply went black and would no longer turn on (at all). No standby light and no typical PSU relay click etc. Absolutely dead.
    Pulled it apart without doing much research first, suspecting the power supply as it had a faint buzz (I guess due to the forthcoming found short), investigated PSU for some time and concluded there was no fault that I could spot with the board removed.
    Came to learn after a bit more research...
    02-06-2023, 08:59 AM
