Lg 50pt250u plasma tv
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    I have this PLASMA TV on my workbench for repair. When plugged in to the 120Vac I hear the relay click ON then a few seconds later click OFF. The PSU self-test proved the PSU is OK and Vs, Va,M5V, 17V, etc are where they supposed to be at. The Vs goes from the PSU to the Y-sus Bd. and from the Y-sus Bd to the Z-sus Bd. With the Y-s connected and the Z-sus Bd disconnected the Vs is correct at 205Vdc. I deduct that the Z-sus is faulty and pulling down the Vs supply.
    Z-sus Bd.: EAX63529101 EBR71736301
    Y-sus Bd.: EAX62846401 EBR7183E6301
    My question is: With the Z-sus disconnected and the Vs and M5V stable on the Y-sus, should I be getting Vsc produced on the Y-sus or would that only come up with the Z-sus connected and working?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Lg 50pt250u plasma tv
    Anybody??
    • Biruslapio
      • Nov 2013
      • 552
      • Brasil
      first thing,check Y-buffer boards for shorts or blown ICs.
      if no problems there,keep Z-SUS disconnected,check Y-SUS VSCAN and -VY,if it does not produce these voltages,logic board may be disarming the set because Z-SUS is not present,then you'll have to remove and check the fuses,IGBTs and 2Watts resistors on Y and Z boards.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Thanks for the reply Biruslapio. IGBTs OK on Y-sus Bd. Y-buffer has no shorts. Thanks for the reasoning why Vscan not producing, as Z-sus Bd. disconnected Logic Bd. disarming the set.
        • Biruslapio
          • Nov 2013
          • 552
          • Brasil
          Take a look at these red circled points on your Z board,if none of the SMD/PTH resistors are open,or any IGBTs reading low resistance between the pins,then do the same to Y board.
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            Thanks a lot!!
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              IBGTs on the Z-sus shorting out. I'm surprised they didn't blow the fuse. I can get a used board. I think I'll go ahead and buy it. The Y-sus Bd. seems OK. Thanks for the advice. I'll update when I install the 'new' Z-sus Bd.
              • HSVHEL
                • May 2020
                • New Zealand
                Hi Andrew
                What was the outcome of your repair here, i believe i may have a similar condition with my Zsus board.
                With it connected the unit will power on, then return to stand by.
                With it removed, the unit will power on and remain on, but produce no picture or start backlight
                • PlasMatt
                  LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                  by PlasMatt
                  I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                  09-20-2025, 06:50 PM
                • Salvatore057
                  plasma TV Lg 42w451 - why is the zsus igbts damaged when the ysus is plugged?
                  by Salvatore057
                  I am trying to fix my plasma TV which is not powering on due to damaged IGBTs. I have changed two igbts and 2 IC drivers on the zsus and also two igbts on the ysus.
                  Now everytime I plugged the ZSUS and the YSUS boards to the power board, the two 30f124 IGBT on the ZSUS are damaged and the TV stays in standby mode. When I plug the ZSUS board alone the TV turns ON but I do not see pictures. When I plug the ZSUS board without the two 30f124 IGBTs and the YSUS board, the TV powers on with a picture.
                  I am lost, should I change the YSUS board? Is the YSUS board damaging...
                  04-29-2018, 01:29 PM
                • JDC
                  LG 60PB6650 - Bad ZSUS (3.8v to YSUS instead of 16v)?
                  by JDC
                  Make and Model: LG 60PB6650-UA
                  Issue: Turns on, no backlight, can hear static (no channel)
                  I've been repairing TVs for a couple years now. I know how to use a multimeter for the most part and know how to test most components for shorts.
                  The power board connects to the ZSUS and then connects to the YSUS. The ZSUS is where I believe the failure is because the 16v line is only 3.8V, even when I disconnect the ZSUS from the YSUS.
                  This particular model seems to have a common failure with its YSUS. My goal earlier was to prove the YSUS was bad so I could...
                  09-13-2018, 02:12 PM
                • divingfe
                  LG Plasma 50PA5500. Sound, no picture !!
                  by divingfe
                  Sorry if this is too repetitive, or in the wrong place.
                  I'm new, and having much the same problem. My LG50PA5500 TV has been working flawlessly since new. The other day, while in the midst of watching a broadcast DTV channel, the entire screen suddenly and silently went dark (no snaps, crackles or pops); sound, channel selection and inputs all work OK.
                  I have checked connections and voltages from: stdby, pwr supply board fuses, psb output voltages to Zsus board and its fuse, output voltages from Zsus to Ysus and its fuse. All precisely normal!! I've also checked voltages to the...
                  06-19-2021, 06:36 PM
                • tofik
                  PANASONIC TX-P42X10Y Plasma TV damaged after a power spike
                  by tofik
                  Hello, I have an PANASONIC TX-P42X10Y Plasma TV, purchased new in 2009.
                  Unfortunately plasma is not working at all after a power spike. Standby LED is not even working.
                  I did some quick tests, YSUS + ZSUS MOSFETS and IGBT's are free from shorts, diodes on these modules seems to also be fine, buffer board is free from shorts as well.
                  Anyway I focused mainly on the PSU, did some voltage tests with the results as below, I attached them on the photo (also please see attached PDF with the SERVICE MANUAL for this model, page number 43).
                  I understand...
                  02-17-2023, 02:34 PM
